04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Help!!! stalling at idle
Old Jul 12, 2008 | 12:51 PM
Rallilanc's Avatar
I'm having a problem with my car stalling out at idle, but runs fine as long as you keep your foot on the gas. Anyone have any ideas of what the cause could be???
Also i just noticed there is a very strong smell of gasoline when i turn the car on.
Old Jul 13, 2008 | 09:17 AM
RalliDew's Avatar
possible TPS seems to be the most commin when thats happening , i know this is in the turbo section but are you turbo, and about the gas i would go through the injector seals and fuel rail section to see if you can see and standing gas or dripping gas that can never be good but untill you locate the gas problem dont concider what i said b4 the last thing u want is to catch on fire so u can turn your key all the way on with out starting to ge the fuel pump on and take a look around to see if u can see gas leaking this maby be the whole problem ether way just be safe about it.
Old Jul 13, 2008 | 11:09 AM
Rallilanc's Avatar
yes i am turbo.
Just wondering if maybe my spark plugs are bad??? The car was running fine until I got on it pretty good then had to take my foot off the gas really fast. At first I thought maybe i just flooded the engine with gas, but i'm not really sure. Would that cause the engine to fumble at idle or cause my spark plugs to go bad.
Old Jul 13, 2008 | 11:14 AM
RalliDew's Avatar
you could as thye say fowel them out but you would have to take them out and see flooding proly isnt going to be the factor of that if it is then maby they craped out, wut plugs and heat are you running on that??
also hard to say if it would flood i dont really understande the rrm 5th ijector concept but i know at a certain rpm it dumpes fuel but i dont know if thats also controlled but throttle pos ether so if it wernt and u were at high rpm then u let off the 5th injector would still be dumping extra fuel into it but i can only assume u have a a/f guage in it and would have noticed it going way off the chart if that were the case.
Old Jul 13, 2008 | 12:05 PM
Rallilanc's Avatar
i'm running the stock plugs, and i wasn't looking at the a/f meter when it first happened but when i am able to get the car going it is very very rich...
Old Jul 13, 2008 | 05:29 PM
RalliDew's Avatar
could be ur prob i was sure that kit came with lower temp plugs. maby time to switch but pull one or them out and have a look.
Old Jul 13, 2008 | 06:48 PM
Rallilanc's Avatar
the plugs used with the kit are the stocks... Hopefully i can figure this out soon i really need my car next week
Old Jul 14, 2008 | 11:14 AM
RalliDew's Avatar
well i believe that a heat of 7 ( NGK IR) is ideal for the turbo set up but once again thats jsut my opinion you really gotta take a pic of the sparkplugs
Old Jul 14, 2008 | 01:03 PM
SSP-Ralliart's Avatar
It could possibly be plugs but if they are that fouled they would create a missfire with higher load. Since you are turbo check to see if you have a tight seal around your MAF also make sure that the element is clean. Could be part of your problem.
Old Jul 16, 2008 | 01:53 PM
evo323's Avatar
Sounds like a recirc problem when the throttle plate closes. check for your recirc valve, I think it's not doing the job right. Just a thought.
Old Jul 16, 2008 | 08:30 PM
Rallilanc's Avatar
i've had a couple people say it could be the maf, so i'll check it out when i can. I've had softball every night this week so working on the car hasn't been an option. If anyone knows what softball is like it means just getting wasted and having no time for anything thing else. At leat since my car is broke down the wife has to drive!!!!!
Old Jul 17, 2008 | 05:03 AM
evo323's Avatar
well, let us know when you fix it, just to know what it was for future reference.
Old Jul 17, 2008 | 07:55 PM
Rallilanc's Avatar
no prob another softball night so it is lookin like this weekend i'll work on it.
Old Jul 19, 2008 | 09:45 AM
RalliDew's Avatar
dig up anything yet?
Old Jul 19, 2008 | 10:57 PM
Rallilanc's Avatar
not yet.... tried cleaning maf and spraying carb cleaner in throttlebody. it worked for about 35mi and then started up again but found out that coming to a stop slowly will not stall it out but having to stop regular or quickly will stall it out... maybe a vac leak but i don't know where i checked everything
