04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Another turbo build
Old Aug 11, 2008 | 05:49 PM
  #31
DangerousDan's Avatar
the one on the flange, for lack of a better word
Old Aug 11, 2008 | 06:12 PM
  #32
ralliartN20's Avatar
awesome how nice of mitsu to place that there for us
Old Aug 11, 2008 | 11:03 PM
  #33
PR_Mivec's Avatar
Originally Posted by ralliartN20
So you think that turbo will work well? I was afraid it wouldnt spool well. Also got a Tial external wastegate with 8lb spring but im going to get a 5lb one. Also have a greddy BOV. Will get pictures up soon of how things are coming along. Going to have the Turbo mani made soon.
the turbine i was going to put on the car was a t3/t4 hybrid and it makes full boost at arround 3.5k (correct me jorge if im wrong) it was not my first choice but it was new at a good price....
as far as turbines is concerned:
to4(t/4) even a 16g and EVEN a gt35r are good turbines to put in REMEMBER it is a 2.4L engine puffing the thing...... not a 1.8l or a 2.0 (and even w/ a 2.0 you can put in a gt35 and spool it quick and nicely)
if you want good accurate info on the Litter to Turbine thing
go to
www.tubobygarret.com
Old Aug 12, 2008 | 06:47 AM
  #34
Well so far i've managed not to spend a dime and have gotten everything from friends for free. So I cant complain. Also never got a awnser from anyone to as if they thought I would be safe driving the car without a tune at 5-8lbs as long as i had a 255lph fuel pump, evo 8 fuel rail, at least wrx blue top injectors and a adjustable FPR with gauge. I figure with the fuel upgrades and turn the FPR up I should be safe as long as I stay out of WOT right?
Old Aug 12, 2008 | 08:21 AM
  #35
PR_Mivec's Avatar
ehhhhh it is never safe to run w/o a tune BUT as long as you stay out of boost completely you should do fine
Old Aug 12, 2008 | 08:49 AM
  #36
BlackRaven's Avatar
+1. Do you have a wideband to monitor as you drive just in case? Just stay in vacuum and you'll be ok for now. As far as numbers at a fully tuned 5psi; I dynoed at around 210whp (similar tq) on a Dynojet, so you're current goal is definately do-able
Old Aug 12, 2008 | 09:00 AM
  #37
qlitv's Avatar
Well it makes full boost at 4k to 4.5k hope it can be corrected with a tune....
Juan..... Injectors received!!!!!
Old Aug 12, 2008 | 09:40 AM
  #38
well then with my T4 I will reach full boost a little later, around 4.5-5k I would imagine. Shame.. should i switch to a smaller turbo? or stay and try to find other way to spool it a little faster? I always have nitrous to spool it
Old Aug 12, 2008 | 03:34 PM
  #39
PR_Mivec's Avatar
excellent.. let the madness begin
Old Aug 12, 2008 | 05:01 PM
  #40
what kind of injectors you using?
Old Aug 12, 2008 | 09:55 PM
  #41
qlitv's Avatar
740cc wrx modified stock injectors
Old Aug 13, 2008 | 05:49 AM
  #42
Anyone know if RC engineering has a injector we can use or if they can bore our stock ones?
Old Aug 14, 2008 | 09:21 PM
  #43
qlitv's Avatar
I think you can use the one they make for the 2.0L wrx
Old Aug 15, 2008 | 01:35 PM
  #44
any injector, aftermarket or otherwise, for the base wrx (search for applicable model years) should work in our car.
of course, that should be common sense...
Old Aug 15, 2008 | 02:49 PM
  #45
stEVOx's Avatar
IIRC it needs to be side feed high impedence(sp?) type injector
