04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Another turbo build
Old Aug 4, 2008 | 05:49 PM
ralliartN20's Avatar
Another turbo build
So been away from the forums for some time, have had good sucess with runnin nitrous on the RA, a 100shot from a Nitrousoutlet.com Wet system along with intake, exhuast, drag radials and about 20 runs, dip'd her down into the 13's.
Well now I want the same power but all the time and its time to go boosted. At first just going to throw together a very cheap setup to get me goin and we'll see how it goes from there, already have a 14b turbo, SMIC, dsm 450's but from the little researching i've done so far you cant use those, so looks like evo 8 fuel rail with wrx injectors and a adjustable FPR, going to use a B-series turbo mani with the 4g69 flange, as for management need to research some more, only going to run like 5lbs until i get the whole setup line'd out on a dyno. So stay tuned should be interesting lol
Old Aug 5, 2008 | 01:44 PM
DangerousDan's Avatar
sounds like you've done loads more research this time
if you are not concerned with obdii (it doesn't sound like it) spend the money and have a shop run a full standalone system. with your goals it's the best thing to do, given that there is no piggyback available that's 100% up to the challenge.
Old Aug 5, 2008 | 04:01 PM
I seen another thread while i was researching posted of a RA that Oddball turbo & performance built that that is now turning out 420whp at 20psi according to them. They also say they have succesfully got the e-manage to work well with the RA. They are located about 3 and 1/2 hours from me so Im thinking of contacting them and see what they can do for me.
Old Aug 5, 2008 | 04:43 PM
stEVOx's Avatar
good work, but why that turbo? isnt it a tad small or are you going for a no lag approach, coz isnt the common size 16g(i assume 14b is smaller)
also why a sidemount intercooler, sleeper?
Old Aug 5, 2008 | 05:14 PM
Mainly the reason for those parts is cheap and availability, I have a 91 talon tsi that im rebuilding so i have the stock parts from it. The 14b is small, but with our cars not having a high redline like a honda I rather have the quick spool. I mainly want to get it boosted at a very low level so I can concentrate on prob the most hardest part of boosting our cars, the engine management.
Once I find a good route to go and tuning the car is lined out, then I will go to a bigger setup with bigger numbers.... Crawl, walk, run kind of thing.
Old Aug 6, 2008 | 01:23 AM
stEVOx's Avatar
kool, keep us posted, would like to see this turn out.
Old Aug 6, 2008 | 01:10 PM
it doesn't take much work to get high numbers, but getting a good usable powerband... more thought has to go into the project. there is an old saying: HP wins dyno competitions, TQ wins races
Old Aug 6, 2008 | 02:59 PM
...our cars can shure put the tq numbers when it comes to bein compared to other cars in its class. Ill be happy with anything over 200hp at 5 psi on the 14b, should be easy to attain right?
Also. I see that RRM now offers their piggyback with program software so that you can tune it yourself. Does it have enough tuning ablities to run a custom turbo setup reliably?
Old Aug 6, 2008 | 03:04 PM
PR_Mivec's Avatar
yes it does
Old Aug 6, 2008 | 04:05 PM
outstanding, then unless anyone would suggest otherwise I'm going to use the RRM piggy for management. I have a good tuner in town that works at the shop I go to for dyno pulls.
Old Aug 6, 2008 | 09:19 PM
PR_Mivec's Avatar
be sure to buy the one that controls timing and fuel
and good luck
Old Aug 6, 2008 | 11:41 PM
stEVOx's Avatar
i believe the greddy emanage blue has been used in the past by some people
and RPW uses and supplies haltech(sp?) e6 and/or e8 piggybacks that may be worth looking into ...
http://www.rpw.com.au/shop/index.php...limitstart=200
Old Aug 7, 2008 | 07:38 AM
ty I was looking into the e-manage as well because i seen another post where someone had used it with sucess.
Old Aug 7, 2008 | 12:43 PM
Originally Posted by PR_Mivec
yes it does
I thought that the RRM turbo unit was set up for a fifth injector, and it did not adjust fuel on the stock injectors.
Old Aug 7, 2008 | 07:06 PM
RalliDew's Avatar
when u get the b series mani make sure u get the one were the waist is off the the side b/c if not you will have to switch to the civic radiator witch i would do anyways cause a alum radiator for those are cheep.... just a tip. and to run the evo rail with a return system you will need to get an ES lancer fuel pump assem then doit.
