RIPP BRat Box ECU add on
Hi guys this seems to be too good to be true isn't it. Turbo guys migth benefit from this especially the ones running the RRM kit or using piggybacks.
http://www.rippmods.com/RIPP_BRAT_Bo...mbrtb-0009.htm
Did you read the extended information this is not a PIGGYBACK you will need a piggyback along with this to run adjustments, what this does is basically trim the signals to some point so that the ECU does not realize it has been modified. Quite clever but expensive because you will still need a piggy but at least is another option.
damn... i think this is one of the best posts i came across in a while... awesome. this should make tuning with my piggyback a bit easier and more permanate. somebody buy this and try it out, let me know if it works with the split second piggyback or easy to tune with a turbo kit please.
awesome post migue
awesome post migue
Nope Jorge wants to eliminate the use of the throttle by wire and use just a standard wire throttle in order to use the megasquirt, I told him my understanding is that the Galant 200-2003 throttle is a cable one and works as a direct fit.
ohh ok thats good to know thanks but I've read about those computers and you can control the fuel and the timing only and leave the stock ecu managing the other components of the engine. You have to make too a custom crank trigger sensor.
I would seriously advise against this. Stay away from RIPP and as far as this product is concerned its just a really expensive E-bay resistor. Thats why if you talk to them they wont tell you exactly what it does or how it works. On C4G we had a member pull it apart and pretty much reverse engineer it to find out how it works. This is just my Opinon though take it or leave for what it is.
Thats a lot of work changing TB's and the Gas pedal and everything, but good luck hopefully it works out for you guys
I don't think the pedal has to be changed, luckily the ralliart has a hydraulic cable that gets as far as the passenger side headlight , there you will find a TPS and the system that acts as a throttle then the signals get sent from the ECU to the Throttle by Wire at the intake manifold, so if you go standalone just remove the throttle at the manifold put a mechanical one and use the oem cable or fabricate a new one. To be honest if you are going standalone this shouldn't be a problem.
, anyway I have attached two images explaining the layout the first one is a picture of my engine bay , follow the red line between the radiator and the engine and it will guide you to the throttle TPS housing. The second one is a close up of that assembly. Again our engines may have the same engine code but there are trivial differences between them for instance the intake manifold on your engine is different and so is the cylinder head. Anyway the idea is to remove that cable and housing and the stock electronic throttle, install a 2000-2003 throttle and put the end of this cable to the galant throttle, calibrate the galant TPS to work with the megasquirt and there you go.... away the Throttle by wire system.
