Throttle problem
Throttle problem
Hi again guys; I'm having now a new problem with my throttle because when the turbo begin to make boost, the throttle closes and I don't know how to trick it so I can interrupt the signal from the stock ecu. I will appreciate your help guys. Thanks
Naw, you just need a reflashed ECU. When you clamp the MAF a whole lot of other things go on that you don't want. I just go in and adjust the MAF/TPS table and it won't throw that CEL again.
-Michael
-Michael
jejejej Thanks but I've already put a 65mm mustang throttle body (cable) and the response is like no other. The negative feed is that the air conditioner is not working baaaaa!!! I've got to connect the old throttle body (the stock one) to put the A/C working but at high RPM's don't work at all either.
