04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
head bolts
Old Sep 4, 2011 | 12:44 PM
skesus's Avatar
head bolts
I have read many times about how the 4G69 can not take more than about 10PSI on stock head bolts now my question and i am sure this has been asked many times before is where do you find head bolts that can take 25 psi? I have a spare engine that I will be boring out about .60 soon and am planning on running about 25psi on bigger pistons and rods with a slightly smaller compression ratio but i need to find head bolts that can take it since the stock ones will not. any places come to mind for anyone where i can get something that will satisfy me?
Old Sep 4, 2011 | 01:34 PM
lanzerralliart's Avatar
EvoM Super Moderator
well anything for an evo 8 will fit , arp has a nice selection. But I wouldn't bore out that much the walls between the piston are pretty thin already, if you bore them out that much the risk of cracking the wall grows significantly. The most I would recommend is .20 overbore.
Take some pics of your car and post them
Old Sep 5, 2011 | 03:38 AM
skesus's Avatar
well i was only going to go .30 but the lovely mechanic that installed the turbo forgot to change the timing belt and a cylinder gernaded so i have to take it out untill its smooth again then sleeve back in to maintain strength. guess i will cross that bridge when i get there. the evo 8 is the 4G63?
Old Sep 5, 2011 | 06:49 AM
ouch that sucks , get some pics up
and yes to your question
Old Sep 5, 2011 | 07:13 AM
CrAnSwIcK's Avatar
ARP 4G63 11mm head studs work with our block.
ARP part# is 207-4203
All 7-bolt 4G63 are the same if i'm not mistaken, even 2g talon/eclipse use 11mm studs.
Old Sep 5, 2011 | 11:51 AM
skesus's Avatar
i will be throwing pics up when i get it finished finished or at least right before i get the engine to the mechanic and all of those steps. just have to get a little more money then i can start....so close
Old Sep 6, 2011 | 12:56 PM
CrAnSwIcK's Avatar
https://www.evolutionm.net/forums/sa...tuds-4g63.html
Jesussaves1
Feb 22, 2013 10:56 PM
Evokid8
Jul 7, 2009 05:59 PM
imalancerman
Lancer Engine Tech
Jun 5, 2009 10:35 PM
mr_biggis10
Feb 15, 2008 10:04 PM
jbergmeier
Oct 14, 2005 11:55 AM
