04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
big maps question
Old May 3, 2014 | 07:25 PM
danny1058's Avatar
big maps question
hello i have a question, i have the eclipse rom on md ecu with big maps and speed density to run 2.4 mivec turbo, work perfect but my question is when i tune the big maps the little ones messed up the numbers, is that is normal?? the ecu just read the big maps or both?
Old May 3, 2014 | 08:28 PM
CrAnSwIcK's Avatar
what do you mean by big?
Old May 4, 2014 | 11:11 AM
danny1058's Avatar
ceddy mods... you have speed density to eliminate maf and use map sensor, launch control etc... with that rom you have big maps for high octane, low octane, fuel and timing, plus the normal maps, when i do the big maps the normal maps changes the numbers automatic with strange numbers, in ceddy forum the said "dont worry about normal maps just use the big maps", ok i tune some cars with that rom and work good but i always have the question its that is ok ?
Old May 4, 2014 | 11:19 AM
mavraolan's Avatar
If u are using Ecuflash:
I believe that if you change a map and other maps change's automatically it means you have wrong definition/xml file in your rommetadata. Find and download the correct one in the directory.
domyz
Jul 27, 2022 11:54 AM
babaz7
May 27, 2021 11:35 PM
4b11slayer
Nov 17, 2016 11:30 AM
Evo_Goodness
Aug 30, 2016 04:00 AM
discodino
Aug 2, 2008 12:21 PM
