04-06 Ralliart Engine/Drivetrain (no forced induction)
need some help
Old Dec 1, 2004 | 09:20 PM
insomniac_evo's Avatar
need some help
US Lancers only please, those w/o DRLs
i'm wondering whether we have the same fuses and all, can you help me compare? thanks
Old Dec 2, 2004 | 07:24 AM
sillypuddy's Avatar
somebody wants to turn off their DRL.. keep us posted!!
-joe
Old Dec 2, 2004 | 09:54 AM
bruce988jl's Avatar
whats a drl?
Old Dec 2, 2004 | 10:00 AM
daytime running lights, i want to put a hid kit, but if the drls are still there, it'll messed up the bulb and with lower wattage(on drls) the bulbs will only flicker
so i'm kinda need to compare the fuse box :P wondering if its any diff
Old Dec 2, 2004 | 10:09 AM
kondo's Avatar
I had HID on my solara and i had that flickering issue I fixed it my disconnecting the sensor, it was just a clip that you unplug, If you can locate the sensor on the mitubishi you should be able to follow it and unplug it.
Nick
Old Dec 2, 2004 | 10:31 AM
where was this sensor on the solara?
Old Dec 2, 2004 | 01:09 PM
kondo's Avatar
its on the passenger side on the firewall. On the solara there is a sensor on the dash and then the plug in on the other side in the engine compartment. I am gonna go look at my ralli art right now and see if i can find it.
Old Dec 2, 2004 | 01:42 PM
kondo's Avatar
I think i found it, here are some pics its on hte left side of the engine
Old Dec 2, 2004 | 02:37 PM
whoa wait2, your lancer has DRLs? i thought DRLs are only for canadian vehichles only
Old Dec 2, 2004 | 02:41 PM
er...wait up, i thought that sensor is for air con or sth...
Old Dec 2, 2004 | 04:18 PM
kondo's Avatar
yeah I think you correct because I was testing it and I was pretty sure I did not have DRL's. But if that is not the correct wire the plug looks like that. Check you're headlights and follow them backwords, somewhere there will be a sensor and a plug that looks like the one I took a pic of. Too bad you are so far away or i would come by can check it out and try to find the clip. Good LucK
Nick
Old Dec 2, 2004 | 04:33 PM
followed the wire down just now, looks like it hides near the plug for the foglamps, anyway, tried that other day, a dry day to be exact, its raining here and my car's all wet :P hehe
