04-06 Ralliart Engine/Drivetrain (no forced induction)
emanage does work
Old Mar 10, 2005 | 12:41 PM
Widebody Lancer's Avatar
emanage does work
just to let everyone know it can be done just not the usual way gotta use the harnesses and diff maps to adjust fuel and timing.
Tory
Old Mar 10, 2005 | 01:49 PM
blk-majik's Avatar
you are my hero =) can you dump the base map u are using and email it to me? which harness do u go with? im gonna be doing this soon
Old Mar 10, 2005 | 02:55 PM
I just made very harness.... base map im still waiting for my buddies car to get off trhe dyno so i can tune it so far just played with some things to make sure it works we craked the duty cylce to like 100% and she goes to 100% hehe kinda cool
Thanks
Tory
Old Mar 10, 2005 | 04:34 PM
otter's Avatar
EvoM Administrator
Somebody should write a how-to and explain all this thoroughly.
Old Mar 10, 2005 | 11:47 PM
amg_dragon's Avatar
You allready know I'm interested! So are you saying the greddy harness' don't work? I allready have the injector/ignition harness for the emanage and hopefully RRM will make the jumper harness for the ecu soon. Please give me ANY info like switch settings you can. Please explain what you meant about the harness. Did you just make your own or can the greddy harness' be modified to work?
THANK YOU!!!! You're a life saver.
Old Mar 11, 2005 | 10:35 AM
Thunder-rush's Avatar
widebody.
Finally how'd you make it work..
Old Mar 11, 2005 | 03:42 PM
Arithmetic's Avatar
Exclamation
Yeah, gives an update. What difference have you felt? Maybe we can email greedy and start a GB?
Old Mar 12, 2005 | 11:36 AM
what differences umm woooom pssshhh lol umm lots haha....
no i didnt buy greddy harness cause its a waste of money u can just use a rx7 stereo plug for 10 bucks... thats what i meant.
i havent figureed out how to mdify the maf signal just the map and theres a way around it all to just control injector duty cycle and timming etc.
Thanks
Tory
Old Mar 12, 2005 | 11:50 AM
amg_dragon's Avatar
I may be wrong but isn't that what the 5 screws next to the usb cable for? Or do they only adjust the rpms that the airflow is adjusted? I don't know if they work independantly of the maps or in conjunction with them. I haven't even taken all my stuff out of the bags yet and haven't had the time to search through engrish version of the manual.
edit: I know you tried to hook up MIVEC throught the Vtec controller and said it didn't/couldn't work. I'm just curious if you tried the crank position wire or the cam position wire or both? I just remembered looking on the yahoo forums and I thought they had it written wrong (crank PS wire). The write up was for older JDM lancers with MIVEC and a completely different harness but I thought I'd try one last ditch effort anyway...
Old Mar 13, 2005 | 01:13 PM
those 5 switches are for like harsh ghetto tunning if ur not gonna use the laptop then buy a SAFC...
mivec i dont know how to hook up as of yet im sure it wont be that hard to figure out.
Sold the system i believe tho and getting standalone but ill post up how i did it once i got a sec on the net
THanks
Tory
Old Mar 13, 2005 | 01:22 PM
amg_dragon's Avatar
Hey that's why I asked! Although it looks like they adjust the rpm setpoints for MAF adjustments. That's a mouthful! I think they set the setpoint in rpm that the emanage will be altering the maf for. Is that closer? I've allready got the laptop loaded up. I've been waiting for RRM to decide if they're going to make a jump harness so I don't have to hack into mine. Whose cable did you use? Greddy, gilligan's or Simon's? Just curious if you had any problems with communication.
Old Mar 14, 2005 | 04:56 PM
ModernRacer's Avatar
Thanks
Tory
Well all this info is gonna help me out, i'm going tubo as well soon, but i'm gonna try a diiferent aproche, 1st i'm gonna use a Eclipse MAF, 2end gonna use 60lbs injectors & 255lph pump, 3erd AFC controller, 4th an FMU, then will see if i really need a e-manage, i've been talking to a few experts and they say that with all that i should be coverd and not have to use a ECU piggy back of any sorts, so i will see when i get my T3/T4 up and running, i'll keep all you guys posted on my progress.
Old Mar 14, 2005 | 06:21 PM
Switch 1 is 0-2000 or something and swtich 2 is 2000-3000 and so on thru the switchs to 8000 i think and it adjust fuel + or - 20% in those RPM ranges....
FMU??? we have no return lines on our cars stock
AFC? is a piggy back computer that noone could get to work as of yet
still need to control timing specially in MIVEC o itll go boom inm liek 100 K
Thanks
Tory
Old Mar 15, 2005 | 06:29 AM
Boeturbolancer's Avatar
I will personally guarantee that you need to pull timing for boost on the Ralliart. I some spots in MIVEC the timining is about 25 degree's advanced. Try boosting on that, even on race gas, and you'll be needing pistons soon!!
Old Mar 15, 2005 | 07:35 AM
oh i know that. i will take every precaution needed to make sure that all is working fine, i work in a Dealership, and my Electronics tech want to help me with this issue to see if we can come up with a easy and simple way around this problem.
i'll let you guys know what i find
brokeblueevo8
12
May 1, 2008 12:15 AM
army685
Oct 2, 2005 01:07 PM
datdjrobp
Aug 17, 2005 03:19 PM
