Works Clutchline
Works Clutchline
Anyone know if this replaces the entire clutch line or just the restrictor section like RRM's clutchline?
http://www.worksevo.com/store/produc...roducts_id=164
That's what I was thinking, but after reading their descrition it sounds like they are replacing the rest of the rubber hose at the top end of the line.
This one replaces the rubber hose (check the works thread in the vendor section), so it doesn't remove the restictor. Using this in conjunction with the RRM line will give the best possible pedal feel.
I would expect that the WORKS clutch line would make the pedal a little more stiff and not so squishy. The RRM line by-passes the restrictor making the clutch grab more firmly. But If I can use both it would be awesome.
Originally Posted by vonzipper
what does this clutch line actually do?
