CAI with Bypass?
Originally Posted by DonLi
I see alot of people get the by pass valve ofr there intake. What does it do and does it make the intake more restrictive?
The valve installs along the upper portion of the inlet pipe on the same axis as the throttle body centerline. Should a drop in pressure occur within the pipe due to filter submersion, the valve shuts down induction at the filter and routes incoming air through its external orifices, eliminating any chance of water ingestion.
Yea, I live in michigan where there can be a lot of precipitation so i think im going the bypass valve. Also I was wondering if anyone knows anyone here that has experienced hydrolock and what exactly happens.
...anyone here that has experienced hydrolock and what exactly happens.
About 10 years ago, my mom had an 80-something Volvo and decided to follow this 4x4 through about 2-3 feet of water. Well, on her car the intake was real low, behind the front headlight. Needless to say, sucked a bunch of water into the engine. Since water can't compress like air, bent the **** out of the rods and valves.
You may as well buy a new engine when this happens.
never seen it first hand here in texas, and trust me ive seen some crazy ****. (woman complains of a smell in her lincolin town car, i find a dead calf in her trunk so infested with maggots we had to call the company that cleans out ambulances to get it out)
Originally Posted by BudweiserJason8
Is it possible to install an air/water bypass on the RRM cold air intake?
like someone said earlier about the filter needing to be completely submerged to hydrolock, thats true. the intake has to pretty much be sucking up all water and no air to hydolock. you might stall in some fairly large puddles, but not hydrolock.
as far as restrictions, i heard awhile ago that if you put a bypass on, it reduces the performance of the cold air to the performance of a short ram. i can't see the truth to that but it probably does give the cai some restrictions.
Originally Posted by mitsutech005
again a short ram produces more power than the cai as long as you dont have heat soak
The bypass isn't restrictive. The only downside is that it creates a touch of turbulance in the intake pipe.
The way a bypass works is really simple when you see it. If the vacuum becomes strong enough in the pipe, it pulls open some flanges around the perimeter of the bypass, letting in air from there, instead of pulling it up from the CAI.
Originally Posted by k3lv
mitsutech could u elaborate on that? A SRI produces more power as long as u dont have a heat soakeR?
This is a recent topic.
i dont think you really need it. i have went through deep water before and i even cut a hole near my fog light to allow for air flow in and nothing happened yet.
If you want my info about the bypass valve go to the aem website. they have a video of the bypass valve in action.
