04-06 Ralliart Engine/Drivetrain (no forced induction)
CAI with Bypass?
Old Feb 21, 2006 | 11:48 PM
DangerousDan's Avatar
it is really simple. the valve is a plastic frame with rubber flaps on the inside of the frame. there is foam surrounding it to act like a filter in case it is needed. when the passageway is blocked(ie submersion) the flaps suck in and let air bypass the bottom of the tube. you have install the bypass valve in a certain aread of the intake tube for it to be effective, you will probably lose some power, and you probably will have to cut your intake tube. AEM actually supplies you with a paper template so you can cut the intake tube to the proper dimensions. The valve aslo comes with a CARB sticker to put on your intake. I helped a friend install his valve onto his AEM intake. We experienced a slight loss of power, but that was on a Civic EX
Old Feb 22, 2006 | 05:22 PM
deathsythe12's Avatar
in P.R it rains a LOT and i have the RRM CAI and i've never experienced this problem.
SEETO
Nov 26, 2016 07:57 AM
herbal77
Oct 23, 2004 09:13 AM
illuminati
May 1, 2004 11:05 AM
Silvercar
Oct 23, 2003 04:30 PM
mxpx5678
Oct 9, 2003 04:30 AM
