04-06 Ralliart Engine/Drivetrain (no forced induction)
Possible cam
Old May 9, 2006 | 11:02 PM
Ralli04Art's Avatar
Possible cam
Okay looking at the evo 9's cam gears, the mivec cam looks EXACTLY like ours. so is it possible their the same? is it possible that aftermarket cams for the evo 9 that the mivec one will fit our cars?
Old May 10, 2006 | 12:28 AM
KillahB's Avatar
Are you talking about the cam or the camgear because you said you were looking at the camgear and then asked about the cams... did you pull the head of the Evo or what?
Nonetheless, I dont think it will work. The 2.4L MIVEC , doesnt our MIVEC control both lift and valve timing, where the Evo only controls lift?
Old May 10, 2006 | 07:19 AM
Ralliart50's Avatar
The MIVEC engine in the EVO is a DOHC. That means the cam wont work for sure. You could probably get the cam gear to work but I personally wouldn't try doing it.
Old May 20, 2006 | 11:10 PM
Ralli04Art's Avatar
im talking about the cam gear itself, yes the evo is DOHC so it has two.
look at this picutre of the evo 9 engine.
notice the cam gear on the right. it looks exactly like our cam gear. so an aftermarket cam gear set for an evo obviously comes with 2. so would only using the one that would go on the right fit our engine??????with a different belt.
Old May 21, 2006 | 12:10 AM
ralliart329's Avatar
I don't know to much about the evo but i think KillahB is right. If he is i wouldnt try it even if it looks like it would physically fit.
Old May 21, 2006 | 07:36 AM
otter's Avatar
EvoM Administrator
My understanding is that the cam gear for a 3G SOHC Eclipse will fit, so why bother with an Evo gear?
Old May 21, 2006 | 07:50 AM
do you have any suggestions on a good brand?
Old May 21, 2006 | 08:19 AM
otter's Avatar
EvoM Administrator
Aem.
Old May 21, 2006 | 08:21 AM
thanks.
Old May 21, 2006 | 09:38 AM
Ralli04Art's Avatar
no it will not. i have tried. the "teeth" are different.
Old May 21, 2006 | 12:13 PM
major downer man at least i didnt run out and order one.
