ROAD/RACE-Stage 3 Clutch for the RA.
yep, surface area is an inverse relationship, the only difference between this and a full plate is mashed potatos, er sorry I'm hungry, heat dissapation will be better on the full surface. this would only be a problem if you can't drive or if RRM(act's clutch according to RRM's website) did not use the proper materials. clamping force, not surface area, determines torque capacity along with three other variables. if you follow the link in my previous post you will be somewhat overwhelmed. sorry its a honda/acura site though
and I would agree, if you sold two already this was way overdue. wait until you fab us some cams
Originally Posted by ROCK
I believe it is inverse relationship, more pressure per square inch but 4 puck grabs alot harder also due to materilas used on the friction surface. I also beleive it operates in a higher heat range than typical clutch disk.
We sold 2 today so this must have been way over due
ROAD/RACE
ROAD/RACE
lol, sorry about that. It was either that or plagiarize the information as my own. I'm all about giving credit where it's due, especially when it comes from a source who claims to have gotten an email from the president of a clutch company. It just seems like people might listen easier. Also, if that guy ever googles his name and sees that post if it really wasn't him, or they didn't have permission to reproduce an article by him or something, then I won't be in trouble
Rock, does the 4 puck design comes with springs or solid plate? Ill be damned if I had to chatter my way out from launching.
Also, can I use that Hard *** clutch with the light flywheel you guys sell? My thought is to replace BOTH the clutch and flywheel at the same time, so any info will be appreciated
Since I guess your Turbo RA must be sporting this clutch already I guess that the tranny can take the punishement...Mitsu trannys are not known to withstand that much tq
solid meaning no marcel layer? very good hookup and lot's of chatter then. four puck design makes it lightweight. higher pressure plate holds more torque. Sounds like you've aptly skipped stage 2 to me. What plans, if any, do you have for another clutch?
We skipped Stage 2 cause our demands have been for bigger badder clutch. We will eventually have stage 2 with a milder full disk. I hope it is soon.
STAGE 1------Got it
STAGE 2------SOON
SATGE 3-------GOt it
ROAD/RACE
STAGE 1------Got it
STAGE 2------SOON
ROAD/RACE
me too, cause when mine goes out I will go to stage two, three is too hardcore at this point. You guys do some excellent work by the way, and it looks like this piece is no exception. ACT is a good choice too, my favorite.
It depends mainly on how you drive it. If you are slipping the clutch constantly you are going to wear it out pretty quick. All that kind of stuff aside it should bite a little harder, and since there is less surface area to bite you would tend to see more wear because of this. However, higher quality materials and less slippage due to the heavy contact pressure will probably make this clutch last as long, if not longer, when doing NORMAL everyday driving.
ROAD/RACE
