04-06 Ralliart Engine/Drivetrain (no forced induction)
ROAD/RACE-Stage 3 Clutch for the RA.
Old Jun 4, 2006 | 08:42 PM
ROCK's Avatar
We finally have our version clutch done. It is stage 3 cause it is a 4 puck disc and 2300 lbs. Sorry to tease you but I will have more info to post on it tomorrow. I wanted to post cause I know a few guys were waiting for it to be done.
ROAD/RACE
Old Jun 5, 2006 | 03:46 PM
lanzerralliart's Avatar
EvoM Super Moderator
YESSSSSSS....so like 12:01am ....right? i'll be waiting.............
Old Jun 5, 2006 | 04:07 PM
ralliartjapracr's Avatar
its about time!!!!!!!!
Old Jun 5, 2006 | 06:37 PM
ROCK's Avatar
Gotta post picts tonight but price is $499. I am off to get something to eat. When I get back , I will post pics.
ROAD/RACE
Old Jun 6, 2006 | 06:43 AM
ROCK's Avatar
Done. See website under RA performance parts. PIc is up there too.
ROAD/RACE
Old Jun 6, 2006 | 10:58 AM
Ralliart_on_LSD's Avatar
cool
Old Jun 6, 2006 | 12:21 PM
reTro's Avatar
I'm prob going to need a new clutch this year... if I do mostly street driving, should I go with stage 1 or 3? I'm not sure how stiff they are for daily driving.
Thanks again for adding to the product line!!!
Old Jun 6, 2006 | 05:10 PM
MikeyD's Avatar
question..... u cant mod a clutch for an auot can u?? i highly doubt it, but i just pondered my mind.
Old Jun 6, 2006 | 06:14 PM
PR_Mivec's Avatar
the onyl thing i could recomend you is to custom make a converter since autos do not use clutch
Old Jun 6, 2006 | 06:56 PM
otter's Avatar
EvoM Administrator
Time for me to do some learnin', and I'm sure others are wondering as well. Why is this style of clutch (4 or 6 puck) better than a regular clutch? Logic tells me that a regular clutch has more surface area so it should bite better and last longer. I understand some of it has to do with the strength of the pressure plate, but what's the pros and cons of this design?
Old Jun 6, 2006 | 07:25 PM
ROCK's Avatar
I believe it is inverse relationship, more pressure per square inch but 4 puck grabs alot harder also due to materilas used on the friction surface. I also beleive it operates in a higher heat range than typical clutch disk.
We sold 2 today so this must have been way over due
ROAD/RACE
Old Jun 6, 2006 | 07:46 PM
ralliart 04's Avatar
i am assuming its also a lighter design?
Old Jun 6, 2006 | 10:58 PM
ROCK's Avatar
It would be a little lighter for sure.
ROAD/RACE
Old Jun 6, 2006 | 11:03 PM
Lancerguy'03's Avatar
make anything like this for the reg Lancer? or does the RA and OZ have the same clutch?
Old Jun 7, 2006 | 01:35 AM
DangerousDan's Avatar
check this link out
http://www.team-integra.net/forum/di...0&topicid=3180
more clutch info than you can shake a stick at.
Rock, can you give us as much technical information as possible about this clutch, such as material, marcel thickness, and whether or not the material used is sintered?
why did you decide on a puck design over a full plate design? What benefit aside from the shear clamping force(ie heat capacity, weight) should we expect from this particular design over your stage one design?
do you anticipate a 6 puck clutch to compensate for greater heat dissipation and pressure plate for more force as you develop more parts for our vehicle or is this as far as you are going. If this is the end of the line are you going to develop a middle of the road full surface plate of better materials for those of us putting down lots of power but not willing to sacrifice drivability(read chatter)
everyone who reads this post should also read the information contained in the link above. The information is quoted from emails between the president of ACT and someone from team-integra.net.
from reading all of this information I estimate this clutch will be good to around 250 to 300 Tq. I am sorry for the lengthy post and the numerous questions but when my clutch goes out I WILL be going aftermarket. I want to know my options and the reasoning behind it. Which is why I had the link above on my desktop.
Thanks,
Daniel
