Help: RRM CAI problem
I took the car to the dealership for some maintanence work today and when i got home I popped the hood and found the CAI was no longer bolted to the transmission assembly. When I attempted to bolt it back onto the transmission assembly I realized the threads on the clutch assembly had been stripped. I don't want to say it was the dealerships fault because I'm sure there's a decent chance i did the damage during the install, but what does everyone think I should do in regards to fixing the problem? I was thinking about just buying a larger bolt and attempting to re-thread the hole with the bolt. I'm looking for a little input on solving this dillemma, so if you have any suggestions please post. thanks.
Just as a guess, I'd say probably M10x1.25.
Length of 20-25mm.
Are you drilling/tapping, or Helicoiling it?
EDIT: My first reply wasn't meant to be a dig. I've just never seen the tool you spoke of, and thought if you had such a well-stocked store nearby, why try to thread a hole with a bolt?
Length of 20-25mm.
Length of 20-25mm.
Length of 20-25mm.
http://www.canadiantire.ca/assortmen...romSearch=true
This is a link to the drill bit I speak of.
, and get a Helicoil kit.
