bye bye downpipe
bye bye downpipe
Hi guys!!
I have a kind of stupid question but i need to verify, In so many cases if you open all the pipe lines the benefit is in high rpmīs but can some one tell me if in the ralliart is the same case? Cos' I like autoX contest, as you know the track is in first gear, well at least here in my city, so you think getting rid of the downpipe will be benefit for autoXing or will my time be less??
Regards!
Regards!
ok, th downpipe will stay there!
Thanks!!!
but kreepa, about the spin tires, I have that problem, the tires spin a lot before the car launches I donīt know if Iīm stepping to hard or what?? I have bfgoodrich kdw-2 tires on, they are stick as hell, but the launch in the car is horrible, it spins a lot in the place like 2 seconds, my launches are at 2500 rpms aprox.
Thanks!!!
Clutch slip if you are crossing, launching shouldnt be a priority. Just try to get out as fast as posible without spinning much. You can do it by slipping the clutch. Works for me all the time just dont over do it or you will cook your clutch. A regular launch with half a sec of slip works, but you want to slip it as less as posible
