04-06 Ralliart Engine/Drivetrain (no forced induction)
Finaly Had my Pulley
Old Nov 2, 2006 | 06:24 AM
egk-69's Avatar
Hi I just installed my RRM Pulley, and it works great, I dont know, but i can feel more tQ and the car defenetly runs better, A lot
very good part from RRM
Im thinking my next MOD to be the exhaust, what do you guys think about a 2.50 exhaust???
Old Nov 2, 2006 | 06:28 AM
ralliart329's Avatar
there is another thread going on now about this. if you are looking for more lowend stay 2.25 high end 2.5
also don't know what you're other mods are but if you dont have an intake id go with that first.
Old Nov 2, 2006 | 06:40 AM
MITVRX's Avatar
I've been told, 2.25" if N/A and 2.5" if turbo. You can go the 2.5" way, but you'll lose alot of low end and gain in the top end.
2.25" will give you low end- mid and a little top end..
2.25" for driveablity
2.5" for top end performance.
pulley ftw.
Old Nov 2, 2006 | 06:54 AM
egk-69's Avatar
ok let see what i decide to do
also the 4 screws that hold the pulley what torque i have to aply? I dot it by hand but i dont know ...
Old Nov 2, 2006 | 05:04 PM
amax's Avatar
When I put mine on almost a year ago, I asked the same thing. The answer then was nobody knew. Even the instructions I believe said something like "good and tight". You could check with RRM or Joe - the guy that made the pulley, or a good mechanic would probably have a good estimation based on others he's put on. I must say, that's the only thing that worries me about the pulley - whether I've over or under-torqued it.
Old Nov 2, 2006 | 05:44 PM
otter's Avatar
EvoM Administrator
18 +- 3ft/lbs, so not that tight, but I would probably put a bit of lock-tite on those bolts.
Old Nov 2, 2006 | 09:56 PM
MitsuJoe's Avatar
I know the pulley is awesome. Not talking about this Joe...
I would recommend 2.25" for exhaust.
Old Nov 3, 2006 | 02:34 PM
amax's Avatar
I think I need to de-torque mine a bit.
Old Nov 3, 2006 | 03:36 PM
akinakin's Avatar
Definately stay with 2.25".....not 2.5.
Any 'decent' exhaust guy will tell you the same.
I have a buddy that runs 11.2's in a Turbo'd 2.3L 4cyl Mustang (his fun car....as his 'real' drag racer is a 347 SBF Stroker, Mustang II that runs 10's) and he is a 'real' engine builder and exhaust guy for a living.
If he runs 2.25" on his car, considering what he has done to it.....that is good enough for me.
Don't rob yourself of torque because the masses say that BIG PIPES are COOL !...lol. Stay 2.25".
Old Nov 4, 2006 | 07:35 PM
egk-69's Avatar
wow,that really sucks, i have 2.25 on my d16z6 civic hatch, and it runs awesome, even when i had the beat up d15, it runs better with 2.25 than 2.0, and we are talking all motor, not forced induction
my civic h22 have 2.50 straight exhaust (with no curves), and even when i think a h22 flow more air than a 4g69, it is still a 2.4L, the h22 is 2.2L
i dont know, but i think i will try the 2.5, I dont care too much about daily driven
Old Nov 8, 2006 | 02:32 PM
Flybert's Avatar
2.4L can see gains across the board even with a 3". Ask any 240sx guy.
Old Nov 8, 2006 | 02:48 PM
MitsuJoe's Avatar
Across the board, I imagine huge loss NA for 3".
Even in turbo form a 3" will not be needed until over 300whp.
Old Nov 8, 2006 | 04:22 PM
chowetime's Avatar
I think exhaust sizing really does depend greatly on what other supporting mods you have or seriously plan on getting.... so if you are planning to change over the cam shaft adding a set of headers throttle body intake manifold etc followed up with some very good tuning then a good 21/2" press bent will be really good and you could be quiet safe for a 21/2" mandrel bent
Old Nov 8, 2006 | 05:17 PM
Racman709394's Avatar
just to make it clear about the stock exhaust....it outside diameter of the pipe is 2.09. which my local muffler shop and i measured on my RA when i was changing my flex pipe. anyways.....iono if it makes a difference, but it's 2.09 inches.
Old Nov 8, 2006 | 07:25 PM
egk-69's Avatar
yep, i have seen that its like 2" so i dont think a 2.25 dont make a really difference,
