04-06 Ralliart Engine/Drivetrain (no forced induction)
abs light
Old Nov 7, 2006 | 07:14 AM
byc_panty's Avatar
abs light
after installing my piggyback 2 days ago and last night driving on the highway,
for some bizare reason the abs light came on.... I had never seen this light come on in my car...
has anyone had this experience before?
so after getting off the highway, i turned the engine off and started again...and the abs light dissapeared...and hasnt turned on since...
Old Nov 7, 2006 | 10:14 AM
Myszkewicz's Avatar
Probably not related to the piggyback.
Old Nov 8, 2006 | 02:16 AM
reTro's Avatar
Yeah, our ABS lights are kinda quirky. There have been several posts in the past of the sort. I think when the system "reads" something unexplained, it throws the light out of caution.
Once when I was coming to a hard stop in the rain, my car slid for a few feet an my light lit up. Another time I had to stop hard in reverse and same thing.
Prob coincidental, I wouldn't worry about it...
Old Nov 8, 2006 | 03:00 AM
chowetime's Avatar
I think the reason for it that when the ABS light comes on what the cars ECU has registered is that either the rear wheels are not moving and the front ones are and vice versa - the same thing happens when you have a car on the dyno after the dyno run the ABS light will be on because the ECU has detcted that one set of wheels are moving while the other set is not no big deal really if you drive and apply the brakes normally under very low speeds then the light goes out
Retro this is what happened to yours you may of locked up the brakes and the ABS was actually working the light is not there as a fault light but more to tell you it is working
Old Nov 8, 2006 | 07:10 AM
byc_panty's Avatar
thats interesting because wehn i was on the highway, i wasnt applying the brakes at all but just driving...
but since than the light hasnt come on....
