cleaning the air filter
My AEM is a dry filter, I blow it out i with an air gun every so often... Its never really needed it, but i've probably put less than 3K on it... They are rather cheap to replace though...
Originally Posted by byc_panty
for some bizarre reason...ive been getting crappy mileage these days....
Do you warm up your car in the driveway for any length of time before driving? I give mine the time it takes for it to get through that choppy cold-start idle phase before I start driving, but I don't let it sit and idle in the driveway for 15 minutes or anything.
Have your driving habits changed? Short trips will kill your fuel economy.
well i have been allowing my car to idle for around 10mins to let the engine warm up in the mornings... i find that it takes our cars forever to warm up to around 800rpms...
i have no idea if they change gasoline here due to seasons.... my air filter should be clean...cause i installed in end of summer.....
ive driven other cars hard... n it seems like the RA;s have crappy milage... but mine seems to get more noticeable
Originally Posted by Myszkewicz
Do you guys switch from a Summer to Winter blend of gasoline up there? I always lose a couple mpg when they switch here.
Originally Posted by otter
That's a bit excessive.
I clean my cone filter twice per year, once in the spring and once in the fall. That works out to about every 12,000 miles for me.
There's your problem man. TOO Long to warm up the car. Once the needle is half way inbetween the C or the needle is jus on 1k RPM i think its warmed up. Cause when u start the car its around 1300 rpm them drops to the 800-900 rpm idle when its totally warmed up.
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Talking about K&N drop in filters how much oil spray is recommended on it after cleaning in order not to coat the maf sensors? I'm sure visually one can determine wether or not theres too much however, i was wondering if someone had a technique such as spraying from a foot for 4 seconds or just swiping past it etc..
