04-06 Ralliart Engine/Drivetrain (no forced induction)
Fuel injectors
Old Dec 20, 2006 | 03:43 PM
az ralliart 04's Avatar
Fuel injectors
What size Fuel injectors do we have and are they side/top or bottom mounted. also do you think injectors from a WRX fit our car?
Old Dec 20, 2006 | 05:35 PM
otter's Avatar
EvoM Administrator
CAPS is telling me that the 4G94 and 4G69 use the same injectors. WRX injectors work for them so it should work for us. I don't know the stock flow, but I bet you can find it by searching the base Lancer forums.
Old Dec 20, 2006 | 06:10 PM
Myszkewicz's Avatar
I'm going to guess 305cc, based on their identifying mark "HDA305E".
Old Dec 21, 2006 | 03:40 AM
Ryan_VRX06's Avatar
Interesting
too bad it wouldn't give that yummy Boxer purr
Old Dec 22, 2006 | 03:39 PM
ralliart329's Avatar
Are you looking to go with WRX injectors b/c they have better flow? also what mods do you have? when i doing alot of N/A mods to my car alot of ppl had told me that it wouldnt make sense to put in bigger injectors.
Old Dec 22, 2006 | 06:31 PM
well my buddy just upgraded his subru to a stage 3 turbo and all the stuff i could use on my car and he well sell me his old kit from all engine stuff and intercooler and turbo for 500. i could have asked the same question in the turbo forum i know but fuel injectors could fall in both forums. and it'll be a little bit till i put a turbro in my car and wanted to stay NA for a bit so thought i could get some good feed back on what bigger Injectors can do for NA cars.
Old Dec 22, 2006 | 10:50 PM
otter's Avatar
EvoM Administrator
You don't need bigger injectors for NA applications, since we're not coming close to maxing out our stock injectors. Bigger ones would be a solution for the fuel issues related to going turbo.
Old Dec 23, 2006 | 03:55 AM
Not saying this cant be done but there's alot more to think about and this could be a bigger job than you might be prepared for.
he's selling you a turbo intercooler and injectors for 500.
1. is this IC a top mount or front mount?
2. you'll need to bend piping
3. you'll need fuel managment
4. a fuel pump
5. turbo manifold
6. im sure someone who knows more about turboing then me can list at least 10 more good points
Old Dec 26, 2006 | 11:28 AM
hellview's Avatar
ya i dont hink the injectors would do anything. plus the tubo is made for an wrx and i dont think it will fit. at least without major fabrication
Old Dec 26, 2006 | 03:57 PM
MyRoN's Avatar
well good to knwo that the wrx injectors fit our car. nice to find out which one is cheaper
Old Dec 26, 2006 | 04:17 PM
bahamut's Avatar
The RA can't be using 240cc injectors. Its flow rate would bottom out like a G64 within the mid to high 150's crank HP.
get a close up pic of a RA injector. I can tell. Mitsu has always made it easy. Granted Mitsu may have changed their standards now.
"HDA305E" - can't be 305. Injectors will crank out over 200 HP at the flywheel.
Old Dec 27, 2006 | 04:41 PM
ralliart186's Avatar
srry not to get off the injector topic. but you guys from az, "myron" and "azralliart04" email me . there is a club here in az . jus wondering if you are interested... AZLC heres my email.. exhaletech@yahoo.com.. thank you..
proceed with injector tech..
Old Dec 28, 2006 | 12:52 AM
chowetime's Avatar
the stock injectors in our cars are 275cc.... just swapping out injectors with no engine management is not good for the engine... you need some sort of aftermarket ecu... eg, be it the new Haltech interceptor, but if you are wanting turbo then you need something a bit more sophistocated like the E6X
the other parts you need for a turbo is oil lines, BOV, thermo fan, boost controller (or ecu that can help control it) map sensor, wide band O2 sensor, turbo, waste gate... great exhaust setup, clutch, suspenssion, brakes... the list is endless
Old Mar 19, 2007 | 07:40 PM
MITVRX's Avatar
So I have a Haltech Interceptor, would I see any gains by getting these injectors? I mean, would it be worth it or should I go for something else?
Old Mar 19, 2007 | 09:03 PM
chowetime's Avatar
^ no you don't need to be adding injectors to your car yet - The Haltech Interceptor is running your at the best possible level your car is running and tuned at is optimum... your next lot of mods should be the stage 1 n.a cam this will give you a bigger rev range and will give you more horsepower... I would doubt if your car is over the 80% injectors duty cycle but if it was it would of been noticed by Haltech when they installed and tuned the car as it would of shown the car was running lean
