04-06 Ralliart Engine/Drivetrain (no forced induction)
if you have the tactrix cable...
Old Apr 6, 2007 | 05:00 AM
DangerousDan's Avatar
...you must visit this thread and help as much as possible. It's a new forum rule. got there now. no joke, we need help.
https://www.evolutionm.net/forums/sh...d.php?t=254033 <yep, this one here.
^that thread, go there now.
Old Apr 6, 2007 | 06:14 AM
Myszkewicz's Avatar
I don't have mine yet. It should be in the mail by now, though.
Which thread? :P
Old Apr 6, 2007 | 08:28 AM
this one here
or you could go to this one
Old Apr 6, 2007 | 03:11 PM
ralliart329's Avatar
^^excited much. I PMed MJ so see if hes not to far from me ill try to let him use my car as a ginny pig.
Old Apr 6, 2007 | 03:31 PM
otter's Avatar
EvoM Administrator
I'm very happy to see someone with his expertise willing to take a deeper look at our car's ECU. Also, thanks for stepping up, ralliart329. I'm also sending some documentation his way which should hopefully help out.
Old Apr 6, 2007 | 06:11 PM
Myszkewicz's Avatar
My tactrix cable came in the mail today.
Now to save up for a wideband.
Old Apr 6, 2007 | 08:53 PM
awesome, it seems this is beginning to come to a head. All the right people are just falling into place. It's great that we can get some people on board to solve this.
Old Apr 7, 2007 | 01:32 AM
Myszkewicz's Avatar
Well, don't count on me to flash my ECU any time soon. I just got the tactrix cable, USB->serial converter I needed to use the R4 program, and got it all hooked up and working. I've been logging pretty much every time I drive just to get a feel for the software and the normal range of certain values, but I'm not going to be makign any changes with it for a while.
I did get the TPS to display right in Mitsulogger, though. Where it was reading 51.765% to 93.333%, it now reads 0.001% to 99.999%.
Old Apr 7, 2007 | 05:55 AM
well how did you do that? I still haven't had any time to mess with it.
Old May 15, 2007 | 08:44 AM
bump for anyone in WA willing to meet up with EvoM member JohnBradley and work on this project. If you want to be able to tune your RA for free you need to be helping us now!!! It starts with just one person stepping up!!!!
Old May 15, 2007 | 12:16 PM
otter's Avatar
EvoM Administrator
Dan, have you kept up on the progress of base Lancers and flashes? Z_Lancer_Man ran into a HUGE issue when tuning his turbo kit using ECUflash. When we tuned his turbo OZ for WOT, the ecu was hitting loads around 80-90. No problem, we tuned it and worked great. However, we found that the ECU hits those same loads when off boost, causing way too much fuel to be dumped and throwing the car into limp mode. The Evo ECU handles this by having a broader load map. 0-100 for non-boost, and 110-200 (or something close to that) for when on boost.
Anyone trying to flash a turbo Ralliart will have the same problem.
Old Oct 21, 2007 | 11:00 PM
Henrys Ralliart's Avatar
Ive got a question about the tactrix cable. Can you read fuel trims on it or other sensor data?
Old Oct 22, 2007 | 04:10 AM
Myszkewicz's Avatar
Yes, although the readings you will get from Evoscan and Mitsulogger do not agree. I'm not sure if Mitsulogger reads trims correctly, but I know Evoscan does not. One of mine was reading 122% the other day, and I still didn't have a CEL. The reading from Mitsulogger was lower, somewhere around 110%, which is *just* before the ECU will throw a code and the CEL.
The nice thing about both programs is that you can always edit the formulas to make it read correctly, if you gather enough raw data and do a little number crunching.
Old Oct 22, 2007 | 08:50 PM
hmm normally fuel trims are maxed at 25% or 50% adjust with 0% being no trim, maybe then 100% means no trim?
