please help me with safc 2 ps yes i read everything
ok so i got a safc 2 and yes i read every thread but it seems like at some point everything fizzled out anyway someone has to have the pinout for a 06 ralliart if you do please please let me have a peek or do anything to solve this mystery ty
honestly from everything ive heard about s-afc's and RAs, they simply dont work together. when i was trying to do a custom turbo setup ppl left and right were telling me that it doesnt work well with the ra.
The thing is that it does work on the RA, as a couple people have them working on their car. Problem is, they didn't install it themselves, aren't willing to crawl under their dash to figure out what wires were used, and nobody here can figure it out.
exzactly thank you otter im going to do more mucking around tomorrow and hopefully can get more pieces to the puzzle from this forum and i promise if i get it to work then i will make dam sure i get the secret out to everyone...not making a garauntee i can do it but if i can ill spread the word
Is your RPM signal reading correctly? If not, check out the piggyback software thread and try that wire instead. What wires are required for hookup? I have never seen the wiring diagrahm for this unit, can you scan it and post it up? Just the wiring and installation pages, if you want you can email them to me too, but you should post them because I'm not even close to the smartest guy on here.
so i hooked up the ecu agian today and instead of using the maf sensor i used the map setup...started it up and it seems to be runing perfectly fine and all the sensors are working so i don't know is that it.....it does work cause my car is running
knock problem solved in my excitement i forgot to set knock its showing zero now while im driving....if anyone is wondering i haven't noticed much of a gain but it still has to be tuned so ill find out then
