04-06 Ralliart Engine/Drivetrain (no forced induction)
weird bog problem
Old Jan 28, 2008 | 09:11 AM
05_yellow_ralli's Avatar
they just called again and my fuel tank is rusted so bad that it was clogging the fuel filter which supposedly ruined the fuel pump. they want $1000.00 for the tank, pump, and labor to install. does anyone know where i can get these parts cheaper and then i'll just have a local mechanic do it. I allready found the parts cheaper on the internet at www.mitsubishioemparts.com but i was wondering if you guys had any aftermarket ideas?
Old Jan 28, 2008 | 11:04 AM
DangerousDan's Avatar
rusted fuel tank? in an '05? is that even possible?
Old Jan 28, 2008 | 11:27 AM
BlueSteel-06's Avatar
Rusted fuel tank sounds kindy flaky, unless your were pouring water in your fuel tank. And if you did you'd have bigger problems. I have heard of older cars sitting in around for 10+ years having rust in the tank but not new ones which are DD.
Old Jan 28, 2008 | 11:34 AM
otter's Avatar
EvoM Administrator
Aftermarket is unlikely. mitsubishiparts.net usually has better prices than the one you linked to. Also, you could search online junkyards for the tank. All the Lancers, excl Evo, have the same gas tank.
Old Jan 28, 2008 | 03:11 PM
RussellM's Avatar
Plat Vendor
Here is a link for the tank and the pump assy (whole module). Let me know if you need some other parts.
http://www.mitsubishiparts.net/cart/...20083+MN161935
