04-06 Ralliart Engine/Drivetrain (no forced induction)
cooling system
Old Mar 24, 2008 | 08:47 PM
JMONK360's Avatar
cooling system
o.k. so i wanted to do a coolant flush on the ralliart, i checked on "all data" to find out where the thermostat is located, and it's telling me that it's in the back of the engine connected to the lower hose. so right away i'm thinking that the 2.4L is a reverse type system? Has anyone done a coolant flush on the ralliart? let me know if i'm wrong. Cause on the 2.0L lancers the thermostat is located by the upper hose like a normal vehicle. Also what kind of coolant is everyone using on the ralliarts, cause the manual calls for long life coolant, but my coolant was green from the dealer. long life coolant is not green! or is it??? I wanted to use dex-cool extented life coolant which is the same as long life coolant, and it's orange. does anyone know if i'll be alright with dex-cool?
Old Mar 25, 2008 | 07:40 PM
JMONK360's Avatar
does anyone know if our engine is a reverse flow cooling system?? also the location of the thermostat???
Old Mar 26, 2008 | 04:12 AM
Thrice's Avatar
The mitsubishi coolant is long life and his color is green.
In my opinion, I would not recommend to put dexcool in our car for the reason that dexcool is orange and mitsubishi coolant is green... Sometimes it's hard to clean up completly the system so if the two coolant get mixed, it'll make a king of mud. Hard to clean after that...
Old Apr 2, 2008 | 08:37 AM
black ralliart's Avatar
I don't believe we have a reverse cooling system. Our water pump is still belt driven. Can't explain the location of the thermostat though.
Old Apr 2, 2008 | 09:40 AM
otter's Avatar
EvoM Administrator
Dexcool is crap, don't use it. Regular green long-life antifreeze is just fine.
Our thermostat is inside the housing that connects the upper hose to the head. Unbolt the 90* metal elbow (thermostat housing) and the thermostat will be inside. It's not a reverse system.
Old Apr 2, 2008 | 09:44 AM
RalliDew's Avatar
i used a mix of weter water pink bottle with destilled water as mix chart on the back of it goes works great.
Old Apr 2, 2008 | 09:46 AM
otter's Avatar
EvoM Administrator
I'm still on the original factory fill. Concentration is still perfect and it's completely clean. I doubt I'll have to replace it until it's time to replace the headgasket.
Old Apr 2, 2008 | 09:56 AM
RalliDew's Avatar
ya ether way i dont like that dexcool stuff.
Old Apr 2, 2008 | 11:37 AM
SSP-Ralliart's Avatar
Never use Dexcool in the Mitsubishis unless required. GMs use Dexcool. Any 50/50 glychol will work fine.
Old Jun 22, 2010 | 12:54 PM
lanzerralliart's Avatar
EvoM Super Moderator
I searched and didn't find anything , so does anyone know if the evo 8-9 thermostat would fit in the ralliart-04-06? I'd like to get a lower temp one so that's the reasoning behind it.
Old Jun 22, 2010 | 01:12 PM
slc-ralliart's Avatar
Same here. Mine looks as good as new.
Old Jun 22, 2010 | 01:14 PM
Why do you want a lower temp one? Our cars cool great from the factory.
Old Jul 28, 2010 | 11:26 AM
cooler is better and the oem thermostat is set to 180f if the evo aftermarket one fits it's set at 145f ....anyone know about this??
Old Jul 28, 2010 | 01:21 PM
I agree cooler can be better unless the thermostat is not letting the car get up to normal operating temperature in which case it could cause additional wear and tear on the engine.
