Ported throttle body discussion
So if this is true I'm going to go part shopping at a neighborhood pick a part place for a 3.8L tb and endeaver tb and go from there I will keep you guys posted if those work or doesn't work or I will order the proflow unit . But any overbored tb even if its 2.5mm bigger with give you advantage with top end gains not matter what size it is over stock .
So if this is true I'm going to go part shopping at a neighborhood pick a part place for a 3.8L tb and endeaver tb and go from there I will keep you guys posted if those work or doesn't work or I will order the proflow unit . But any overbored tb even if its 2.5mm bigger with give you advantage with top end gains .
not yet im waiting for the funds to do it
btw sorry for the repost my black berry was being lame
Thats one of the reason why I'll prefer the swap over the port. So MAnudata, the inlet needs to be matched... no biggie, thanks for the info, I have a IM in the shop geting done and Ill add the TB, that way I dont end up with a restriction on the setup
BTW, thanks for showing me word I was looking for...inlet...LOL, dont forget it kids
JAJAJA Man you know what my Sig sais. hhehehehe
And yes is not a big deal, but I just dont have the time right now to do it. Next week I will try to finish the Civic (put the bumpers and mirrors on it) and buy the, the... (MARBETE) so I can use it legally and then! I can work with my RA, Modify the Motor mounts, install the TB and port the IM, maybe take it to the muffler shop to make the header. Lets se how this turn out!
And NOW read my SIG again!, HAHAH
I'd like to try it, at some point, but right now I can't be bothered to find one and then go through the hassle of removing my intake manifold to port match it.
^I don't really think its a matter of port matching the manifold (at first). I think that would actually make the situation (in regards to the vehicle dying off at 3000 rpm) worse.
http://www.subaru.co.nz/Technical_Lab/News/
^That article explains how the DBW system works (actually in detail cause every other explanation is very barebones) and it sounds like one of the sensors measures the amount of air coming in at X amount of opening of the throttle plate. When the CPU realizes too much air is coming in it tells the car to die off.
Thats from what I gather. I would assume you would need to get the CPU to except the extra amount of air. That only relates to using the 3.8L throttle body though. I would assume boring out our current one another 2 mm will make no difference at all.
yeah, but the throttle position is not independent of the MAF sensor like the filter or tubing is. you can't measure a change like that because there are still limits the car can control, such as the throttle position. when you change the cars ability to control things, such as moving 100CFM from 10% throttle to 200CFM at 10% throttle you are making much more dramatic changes as far as the ECU is concerned. It can not only measure the air, but it has a reference to compare it to. with a larger intake tract you are simply getting an easier path for the air; it's still regulated by the TPS and therefore the ECU.
no one has cracked the ECU, so you could be right
I am sure there is a quite a margin left into the system since there are many things that can affect the density of air. the ECU can monitor most of those conditions though, at least the most important ones such as temperature and pressure, so
It will be awesome to see a Ralliart with a 3.8L
And about the weight distribution , yes I think it will be F*ckup pretty bad, but for straight line it doesnt matter...
My friends 06 GT Mivec does low 13's traping 106 in the quarter, now take away the fat body for a Lancer's and thats a 12 second candidate without anything major done to it.
I see around your logic EGK, I started believing anything is possible when I saw a 3.0 V6 from an Eclipse in a Mirage, let alone a H22 vtec in a Hyundai Excel...thats not even mentioning a LS1 V8 in a "sapito" Corolla
I have a friend that its working on a project , the car is a Sentra b13 with a nissan v6 engine, FWD! its almost done (altima engine I think it is) and I think that would be harder than a 3.8L eclipse engine on a Lancer,
DAMN that thing should almost fly!!
