Ported throttle body discussion
I heard that in a super street article with spec vs that did the VQ swap , back on topic I found a 3.8L tb at a junk yard its getting cleaned up at my uncles shop and also a spare 2.4 tb . so i will keep everyone posted
so hear it is the 3.8 bolts right up but due the size of it the car idles like **** and the ecu cannot deicde what to do with it . I drove it 5ft and it killed itself due to the idle issue but danm it sounds so bad *** . im assuming that if the mani was ported to match the tb it would work . im going to try more ideas to get this to work i did notice that this can be possible but is it worth it ? im going to place my order with proflow on monday for a tb and even tho its 2mms bigger im sure it wil benefit
1. how do you figure changing a stock part to accommodate an odd part is going to fix a poorly running engine
2. how long did you let it idle after you reset the ECU the first time?
I hope to god you listened to the PR guys. I've said it before, and I'll say it again: if you think you are the first, a Puerto Rican's already done it on the RA.
So, anyone tested this!?!?
I couldnt test it, I sold my CAR, hehe
If anyone wants the 3.8L 65mm Eclipse throttle body, I have it for SALE
https://www.evolutionm.net/forums/sh...52#post5731352
that does make alot of sence seeing as the 4g comes with the 4g69 and the body remains the same for the eclipse the engine jsut changes,
whats the code for the gt v6 3.8 mivec cause my friend jsut toatled his and he has a salvage title now soooo maby free engine for me
I bought the proflow tb now and there is some difference in the car it screams above 4k . I dont think any hp was gained but throttle response has greatly improved since I now have a ported im and the tb
i emailed the company from the link for PnP throttle bodies
guy that emailed me back said the 3.8L should work on the 2.4L the only thing is the intake manifold will have to be bored to match the throttle body
Is this referring to a stock intake manifold? I have an rrm intake manifold and I'm wondering about a bored TB. I see the eclipse TB will work. Just wondering if I'll still need to port the rrm intake mani to match?
Thanks,
Mike.
Thanks,
Mike.
Maybe we need to get a "community" manifold much like the EvoM flywheel.
