04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggy Map
Old Sep 21, 2008 | 12:51 PM
R/A 69's Avatar
Piggy Map
Hey, Whats up. I need a good map for my mods. Right now I have an rrm sri,piggyback, and hks muffler. Soon I would like to add a 0BX header. Any good maps for those mods would be appreciated. I would prefer maps that have been dynoed with good results. Thanks
Old Sep 21, 2008 | 06:01 PM
R/A 69's Avatar
Also my piggyback is making my engine run lean and has a cel on.
Old Sep 21, 2008 | 07:13 PM
joeyj's Avatar
pull the code and read what your engine is saying is wrong, unless you mean the cel is for it running lean
Old Sep 21, 2008 | 07:17 PM
R/A 69's Avatar
the code for the cel says it is running lean
Old Sep 21, 2008 | 07:26 PM
R/A 69's Avatar
i'm thinking about running one of dangerous dans maps but, if someone has about the same mods as me then I would try one of there maps as long as it has good results on a dyno. i don't want to take any chances of a bad tune.
Old Sep 22, 2008 | 06:22 PM
R/A 69's Avatar
no one has any maps for these mods?
Old Sep 22, 2008 | 11:19 PM
joeyj's Avatar
i meant the actually code number like p0171 (just an example)
personally my mods are close to yours, but i've had too many bills to afford to throw $200 towards a wideband o2 sensor to tune my car. im sticking with the stock map for now (when i say stock i mean the RRM one lol)
Old Sep 23, 2008 | 06:01 AM
R/A 69's Avatar
I can't remember what the code numbers were but, I did see the screen from the code reader that said to lean. I am just now getting a laptop to be able to tune my car. I just need to find a good map that does not run lean. At this point I just need a map that has worked good for someone else with about the same mods.
Old Sep 23, 2008 | 09:18 PM
joeyj's Avatar
well it isn't the map that runs the engine lean. The piggyback only effects the amount of fuel injected in during open loop operating mode, which comes on during WOT, and during that time, the ecu doesn't take information from the o2 sensor to adjust the AFR which is what allows you to tune it, if anything, you're getting the lean code from a leak in the intake or dirty MAF sensor, so i would check those, reset the ecu, and see what happens.
Old Sep 23, 2008 | 10:14 PM
R/A 69's Avatar
thanks for the suggestion i will try that.
Old Sep 24, 2008 | 08:50 AM
joeyj's Avatar
yeah man, i threw a lean code like 2 weeks ago when we got hit with a cold front, ecu wasnt used to the change in outside weather temp, so i reset the ecu, erased the code and it hasn't come back yet =p
