04-06 Ralliart Engine/Drivetrain (no forced induction)
+2mm Big Valves for the 4G69
Old Jan 29, 2009 | 12:20 AM
toortool's Avatar
+1mm Big Valves for the 4G69
Performance big valves with the exact 4g69 specs are not available. So Im having them custom made.
Old Jan 29, 2009 | 08:11 AM
Ralliart_on_LSD's Avatar
somebody should jump on this guys.
i would do it, but im getting my valves done by the same guy who is re-doing my head. other wise i would be number two on the list.
good luck.
Old Jan 29, 2009 | 08:16 AM
Gamble97's Avatar
Great price, but don't forget you will be spending money to get the head worked to fit the oversized valves.
Old Jan 30, 2009 | 04:54 PM
toortool's Avatar
to make the overall cost more economical and avoid possible idle issues, ive decided to go with +1mm I/E valves.
you can follow the discussion here
http://club4g.org/board/4g-eclipse-g...valves-gs.html
Old Feb 6, 2009 | 12:39 PM
mr.ralliart's Avatar
I was just asking my mechanic about mods and he recommended me this one, but I'm a noob so can someone explain me what else would I have to buy and what's the cost (approx) of doing all these.
I understood that bigger valves help process more air, which translates into more power, am I right?
Old Mar 6, 2009 | 05:57 PM
toortool's Avatar
my valves are in
4g69 +1 black nitrided ss, swirl polished with flat heads.
manufactured to spec by one of the biggest names in the import performance industry (no kidding).
it takes 3 weeks for these to come in.
send a pm if youre interested in these bad boys.
Old Mar 7, 2009 | 07:13 AM
how much did they cost for a full set? and can u get springs and a hole valve train? or just the valves?
Old Mar 8, 2009 | 12:22 AM
toortool's Avatar
i can reorder a set for 375 shipped, valves only for now
Old Mar 8, 2009 | 06:46 PM
hackish's Avatar
First you have to determine which side needs the larger valves. This is done by figuring out the flow ratio between intake and exhaust coupled with what RPM you want the powerband and what cam you're using. Making more power isn't as simple as just whacking in some bigger valves.
If I get some time next month I'll throw an RA head on the flow bench and see how it does. I spent a little time late last year but never got a chance to get really into it. Some company in the US did a head for someone and it was so poorly balanced that it was pretty much impossible to tune. Some cylinders flowed 3% more than stock and others were like 15% more than stock! I told him to sell his head and I'd do one properly. If he does that's up to him.
-Michael
Old Mar 10, 2009 | 04:56 PM
toortool's Avatar
^pls show us your findings and flowbench numbers on the 69 head
yes, a shop who REALLY knows what theyre doing is a must and flowbenching necessary to get the best results. when all done right, and with proper tune, can give 25% to 30% hp increase (my guesstimate based on others results)
Old Mar 15, 2009 | 07:47 AM
cleartitleskate's Avatar
Yeah the valve train is pretty much virgin in the 4g69 aftermarket. I'm extremely excited to see what kind of numbers can be made by opening that up a bit.
customtoyz
Jul 22, 2017 08:33 AM
senate6268
128
Sep 3, 2015 10:44 PM
Parks
10
Mar 17, 2011 01:25 AM
JohnathanKong
May 1, 2009 10:33 AM
captain150
Jun 9, 2005 08:59 PM
