04-06 Ralliart Engine/Drivetrain (no forced induction)
Any little power gaining tricks?
Old Apr 10, 2009 | 05:56 PM
maxsideburn's Avatar
I know on many of the cars I've had in the past there are small little "freebies" that you can sometimes do to gain a horsepower or two. Are there any thing like that on the Ralliart?
It's typically something like removing an unnecessary part from the intake system or adjusting some kind of sensor or something like that.
Old Apr 14, 2009 | 06:03 PM
Joyrider's Avatar
Here you go http://www.ultimateresourceguides.co...-freemods.html
Have fun !
Old Apr 15, 2009 | 07:46 AM
those are pretty generic. no Ralliart specific ones?
Old Apr 15, 2009 | 01:14 PM
RalliDew's Avatar
i would steer u away and say no/ though im sure there are some . the ECU on the RA is to sensitive and many run into problems short after, and its not free after that.
Old Apr 16, 2009 | 05:48 AM
heh....modern cars. so wierd, lol.
Old Apr 16, 2009 | 07:20 AM
hackish's Avatar
Not free but you can sometimes make decent gains by adding a phenolic spacer on the intake manifold. You can also look at a coolant bypass on the throttle body. Usually pretty cheap on both items.
-Michael
Old Apr 29, 2009 | 02:45 PM
mr.ralliart's Avatar
Hey Michael, were can I get the phenolic spacer and the coolant bypass?
Thanks
Old May 3, 2009 | 08:00 PM
rdc's Avatar
rdc
The coolant bypass is just a fitting that you can get anywhere. In the TB there are 2 coolant lines (entry and exit), just take them out, connect one to the other with that fitting and you are done. What this does theoretically is maintain the TB cooler, although I think you wont feel any difference since the engine bay gets so hot and the TB still gets very hot since heat passes through the IM, through the gasket and into it.
Old May 4, 2009 | 07:29 AM
hackish's Avatar
Mr. Ralliart, I can see about a phenolic spacer.
For the throttle body bypass of course it makes a difference! That, coupled with the phenolic spacer on a number of cars I've datalogged 10-15 degree C drop in charge temps. That translates to some horsepower.
Old May 9, 2009 | 10:47 PM
rory_j13's Avatar
How much cash do you have? Id say intake or something else relatively cheap....cheap thrills lol
Old Jun 8, 2009 | 09:56 AM
EV0-VIII's Avatar
ecutek
