04-06 Ralliart Engine/Drivetrain (no forced induction)
shifter pops out of gear in 1,2,3
Old Mar 3, 2009 | 09:04 AM
byc_panty's Avatar
bla
Old Mar 3, 2009 | 09:05 AM
Sr20kidD's Avatar
sounds like the gears are going
Old Mar 3, 2009 | 09:15 AM
byc_panty's Avatar
so wat exactly needs replacement???
Old Mar 3, 2009 | 09:19 AM
mikeevo21's Avatar
synchros!
Old Mar 3, 2009 | 09:35 AM
Thrice's Avatar
Forget the synchros ! The problem isn't there.
When it happen on a Ralliart, you need the replacement of the shifter cable, because the boushing on the tranny are jammed.
If it's under warranty, bring them the car, if not, write me back and I'll tell you how to repair this problem.
Old Mar 3, 2009 | 09:55 AM
byc_panty's Avatar
thanks guys ill take it to the stealership tommorow
Old Mar 4, 2009 | 08:42 AM
byc_panty's Avatar
k its in the dealership now... gota leave car for 2 days n now taking bus....
but its covered with warranty.. woohoo
Old Mar 6, 2009 | 09:52 AM
byc_panty's Avatar
Old Mar 6, 2009 | 10:27 AM
Spooky_Neo's Avatar
Originally Posted by byc_panty
dang my cars in the dealership for one week..
they took off the transmission and ordering a bunch of parts from states now..
some guy there is telling me my clutch is 80%worn and to replace it is $600 but free labor due to warranty with my transmission issues..
wat da heck..jus wanted to vent
how many miles you got on your car ?
Old Mar 6, 2009 | 10:55 AM
byc_panty's Avatar
80000 kms i downshift alot
Old Mar 11, 2009 | 12:28 PM
bruce988jl's Avatar
Tell them that you'll supply the clutch, then go out and get an oem clutch for half that price...
Also if they're replacing any gears or anything make sure they replace the gear bearings. I had a messed up 2nd gear and my transmission shop replaced it but didn't replace the 2nd gear bearing (looks like a sleeve style bearing) and it went again 3 weeks later. Luckily you're under warranty.
Old Mar 12, 2009 | 08:20 AM
byc_panty's Avatar
ok i got my car back they put bunch of new parts in and i paid 4bills for a new clutch plate and still i can pull out the shifter wihtout pressing the clutch while i drive!
also i can push the gear into second gear wihtout pressing the clutch..
wat t fsck!!
wats goin on?
Old Mar 17, 2009 | 01:04 PM
illusion's Avatar
i did it when I hurt my left knee a couple of months ago people do it all the time my cousin taught me how to do it its call cluthcless shifting and tap the gas pedal while you shift to any gear... just dont do it when you race or when your cruising and shift to 5th gear...
Old Apr 9, 2009 | 02:21 PM
RalliDew's Avatar
well being able to pull it out of gear with out clutch can be due to rev matching if u tap the gas u can pull it out of gear with the tranny lifts load u can also shift with out using ur clutch pedal same way by rev matching , but if its really easy to pull out wile ur accelerating then i would say there is still a problem.
Old Jun 8, 2009 | 09:57 AM
EV0-VIII's Avatar
sound like need the synchros bro
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
