04-06 Ralliart Engine/Drivetrain (no forced induction)
engine cutting out
Old Aug 6, 2009 | 09:05 PM
zachallen19's Avatar
engine cutting out
its only done it about 4 times now but sometimes if im pullin hard around 5000
it cuts a very noticable amount of power but then starts pullin hard again.
has anyone else had this prob
prob just needs a tune up prob wouldnt hurt ive put around 20,000 on the car and the plugs probably havent ever been changed
Old Aug 9, 2009 | 05:21 PM
mitsuyager9's Avatar
your plugs should be good for another 40k miles along with everything else for a tune up....do you have a boost controller on it?
Old Aug 9, 2009 | 07:01 PM
otter's Avatar
EvoM Administrator
I'm willing to bet that, if you haven't already replaced it, its accel pedal position sensor.
Old Aug 9, 2009 | 10:18 PM
joeyj's Avatar
this, but also listing any mods you've done would be helpful!
Old Aug 9, 2009 | 10:37 PM
the car has 88,000 but i put 20 of them on it
so i changed my oil not even a month ago and i checked my oil today (the car dosent smoke at all and dosent leak a drop NONE WHATSOEVER) it was three quarts low dont ask how it isnt blown up. any way im gussing it didnt have enough oil pressure to fully engage mivec ??? but it has to be burning oil because its not leaking any my cat stinks when i turn the car off too.
does it have a boost controller? no because its not boosted
what mods?
4-1 header stainless downpipe (OBX)
cai
thats it
Old Aug 9, 2009 | 10:59 PM
otter's Avatar
EvoM Administrator
If you've lost 3 qts you've got much bigger issues. If you're not mechanically inclined it's time to find a mechanic.
Old Aug 11, 2009 | 04:23 PM
im very mechanically inclined but
tell my what u think
no water in the oil, or oil in the water
no smoke ever
no leaks at all
oil light isnt even coming on
no lifter tick no abnormal noise at all
dosent make sence
Old Aug 11, 2009 | 05:20 PM
SSP-Ralliart's Avatar
did you add the proper amount of oil into the engine? I have to ask this. Also what is your crankcase pressure? Should be under a vacuum when running but positive pressure can cause some issues. If you did add the proper amount of oil it went somewhere either out the tail pipe/ internal leak, or external leakage.
Old Aug 11, 2009 | 06:17 PM
otter's Avatar
EvoM Administrator
What SSP said. First thing I'd do in that situation is a leak down test. Figure out if the rings or valves are letting an excessive amount of oil by.
Old Aug 14, 2009 | 04:58 PM
samterry1234's Avatar
i kind of have the same issue with mine, but my oil level is fine. its not at 5000 though either. its when i have my cruise set between 60-70 every once in a while it will... lurch? i guess would be the word. i can feel the power just go away and come back. its like i push the clutch in and let it back out real quick, minus the jerkiness.
it's enough to make me lean forward and then push me back in my seat a little bti
