04-06 Ralliart Engine/Drivetrain (no forced induction)
alot of vibration
Old Feb 7, 2010 | 03:35 PM
ArkaneDark's Avatar
alot of vibration
So I'm having a lot of vibration on the acceleration pedal. Most notibly in the upwards of the mid third gear. Is there any mod to make it smootheror not vibrate as much? Something I can do?
Old Feb 7, 2010 | 05:03 PM
slc-ralliart's Avatar
Sounds like something might be broken. Can you be more specific on the vibration?
Old Feb 7, 2010 | 08:24 PM
ArkaneDark's Avatar
It doesn't seem like anything bad, just the higher the rpm's the more vibration. Its notwobbly, just stiff vibration. Its to the point where at the third rpm its about as vibrat-y as, say, a massage thing. So I don't know if its bad?
Old Feb 7, 2010 | 10:10 PM
lanzerralliart's Avatar
EvoM Super Moderator
You should take a look at your motor mounts and if they are bad there's a pair in the fs forums..
Old Feb 7, 2010 | 11:02 PM
ArkaneDark's Avatar
so its probably some sort of mechanical fault? considering i don't know much about motors would it be better if i just took it in for inspection?
Old Feb 8, 2010 | 05:16 AM
Thomar's Avatar
yes.
Old Feb 12, 2010 | 10:50 AM
TheGreek's Avatar
Is the vibration at high speeds or only at high rpm's? Try coasting in neutral at the speed you are usually at when the vibration happens, and see if it's still there.
Old Feb 12, 2010 | 03:43 PM
ArkaneDark's Avatar
yea its definitely rpms...
Old Feb 15, 2010 | 04:22 AM
TheGreek's Avatar
Have a mechanic take a look.
My bet is motor mounts.
usacchamp
Jul 27, 2015 06:41 PM
MR White
14
Mar 3, 2013 10:21 AM
knightey
Sep 19, 2011 10:22 AM
hgby
Sep 30, 2008 09:03 PM
Derek888
35
Dec 22, 2005 02:12 AM
