04-06 Ralliart Engine/Drivetrain (no forced induction)
Flickering Oil Light
Old Feb 8, 2010 | 07:21 AM
Ralliartize It's Avatar
Has anyone ever encountered the flickering oil light at low idle with the RA? Am i looking at a new oil pump,or sender unit. I should note that this happened after I changed my oil two days. Got it changed at Valvoline and they used 5-30w Sythentic. I already called and told them the situation so I'll see what they say. Anyone else have any ideas?
Old Feb 8, 2010 | 07:31 AM
senor_schmu's Avatar
I had a problem like this in my Evo, if the ralliart oil pressure system is anything like the Evo's, then it is probably a corroded oil pressure sensor and since you are in Boston, this seems even more likely.
https://www.evolutionm.net/forums/en...kers-idle.html
Old Feb 8, 2010 | 07:34 AM
Where is it located?
Old Feb 8, 2010 | 08:00 AM
otter's Avatar
EvoM Administrator
The oil pressure sensor is on the back of the block near the center. If you get under your engine and look up behind it, you should see it sticking out there with a single wire coming out of it.
Old Feb 8, 2010 | 08:22 AM
Has anyone experienced these dying on the RA?
Old Feb 8, 2010 | 03:18 PM
mani3461's Avatar
Low RPMs
Same thing happened to me 3 years ago.
The dealer fixed it (warranty), it was oil pressure sensor.
05 RA
EMM
Old Feb 8, 2010 | 03:33 PM
lanzerralliart's Avatar
EvoM Super Moderator
Mine did this a few times a while back but then it stopped ..??
Old Feb 10, 2010 | 06:46 AM
god damn snow.
Old Feb 11, 2010 | 10:08 PM
e\/olution's Avatar
mine flickers when i either brake hard or hit a decent pot hole, but oil pressure is fine and i checked the level it was fine, changed oil not too long ago..
edit: on my evo
Old Feb 12, 2010 | 10:47 AM
TheGreek's Avatar
I agree with otter. I bet it's the oil pressure sensor. I had the same issue with my R/A. I remember it being about $7 at the parts store. The one I got had a different type of connector (male "faston" tab connector instead of a screw hole like the old one), but it worked fine.
Old Feb 16, 2010 | 07:57 AM
Would they have this at autozone?
Old Feb 16, 2010 | 07:12 PM
Myszkewicz's Avatar
Yes, they do.
Old Jan 28, 2011 | 05:20 AM
veloracer's Avatar
Man I love this site.
This issue just started to occur. My R\A has nearly 100k and of course, living in WI, snow + road salt = corrosion.
I'll be crawling under the car and making the change to the sensor.
Old Jan 28, 2011 | 05:41 AM
It's not too hard replace, I think it requires like a 23mm socket, or you can buy the specific tool made for it. Just make sure the car is cold, last thing you want is hot oil on your face.
Old Jan 28, 2011 | 04:29 PM
Raikiri's Avatar
meaning do it while you're doing an oil change or else you'll have oil everywhere?
