04-06 Ralliart Engine/Drivetrain (no forced induction)
Oil light at idle
Old Sep 15, 2010 | 11:10 PM
Buxnbaas's Avatar
Oil light at idle
My 05 RA oil lite comes on at idle, and has since my last oil change when i went to synthetic 5-20 per the owners manual. is this of any concern?
Old Sep 16, 2010 | 05:02 AM
NJRalliart's Avatar
Mine has been doing the same thing for a year now, when I drive on the highway for a while thendrive local the oil light is on/ flickers at idle. Its the oil pressue switch/sensor. Nothing that will hurt anything. I put every kind of high quailty oil and oil treatment and it still comes on.. its/not hurting anything just make sure the oil is full and your good to go =)
Old Sep 16, 2010 | 06:26 AM
lanzerralliart's Avatar
EvoM Super Moderator
Yeah mine did this awhile back I just added a bit of oil and it stopped... Check your level.
Old Sep 16, 2010 | 06:46 AM
otter's Avatar
EvoM Administrator
Replace the oil pressure switch. It's cheap and easy.
Old Sep 16, 2010 | 08:03 AM
NJRalliart's Avatar
or just save your money and dont fix it because it isnt hurting your car. lol or adjust your idle to make it higher, what are you idling at?
Old Sep 16, 2010 | 08:37 AM
My reflash changed my idle to 1000rpms but how else can you change it? Before the reflash ,I tried adjusting the nuts on the tps but the ecu took over and made it the same as before.
Old Sep 16, 2010 | 08:42 AM
NJRalliart's Avatar
idk i just had my shop change it, you might be right i think its back to what it was before lol
