TB Swap
so bumping an old thread. for those that have had this for a while, has it caused anyone to throw lean codes? how about during the winter/colder temperatures? any issues so far?
I have the 63mm and have had no issues. The only bump I had was when I first put it on, it kept turning off after a few seconds. It sounded fine, it would just turn off. If I would rev it, it would stay on..so I decided to take a drive in it and kept revving it while in neutral to keep it on at the stop signs and it learned to breathe just fine.
I'm guessing it wasn't a straight swap for me like others have said because of my current mods? I don't really know, in either case, it's been an awesome upgrade. RPMs at idle are fine. On cold starts it revs a bit higher but when it's warmed up it's fine.
No info on the lean code. CEL has been on due to my header/downpipe.
I've got the Endeavor 63mm, put it on back in january when it was in storage. I drove it like once a week during the winter and it ran fine. Even when relearning never sounded like it was going to stall. When it sits for like 2 days and then i start it, it idles a tiny bit high, but only for a minute or two and haven't thrown any codes. Kind of want to try the GT 65mm and see if there's any difference, but so far its one of the best mods i've done, sounds great, and feels great.
Yes, unplugged battery the entire time I was doing the install. I made sure everything was hooked up properly after the 3rd time it shut off. What made me decide to take it for a drive was the fact that it stayed on if I revved it even a little.
maybe your car stalling out has something to do with the fact that you DID unhook the battery and let the memory erase..and it had to relearn with all the base values, wich obviously arent setup for the larger TB....untill it learns "hey...im getting more air...lemme add fuel...and stay that way since that's the way ill run"..?
did every1 else unhook their battery during their install or no?...jw...
(personally i only have a SRI as mod - wich came w/ the car when i bought it -so its just a thought..)
(personally i only have a cai as mod - wich came w/ the car when i bought it -so its just a thought..)
it's like 90 and beach worthy at the moment.
