04-06 Ralliart Engine/Drivetrain (no forced induction)
Flywheel
Old Dec 6, 2010 | 09:48 AM
ralliartucar's Avatar
Flywheel
I have two questions.
Will a 2000 eclipse clutch work in the ralliarts? I know a guy that bought a new one and traded his car off so I can get it cheap.
How much can the steel flywheel be lightened? I saw somewhere that someone got the factory one down to 12 pounds. But after hours and hours of searching I can't find it again.
Old Dec 6, 2010 | 10:03 AM
veloracer's Avatar
check this thread for a lightened flywheel Al flywheel
as far as the clutch is concerned, I don't think it will work.
Old Dec 6, 2010 | 10:34 AM
I looked at that before, but I can't go with aluminum. I know I've seen where this has been done on a 2.4 but couldve been an eclipse.
Old Dec 6, 2010 | 10:40 AM
Ralliartize It's Avatar
Based on our flywheel being dual mass, lightening it is pretty much out the question. The shops that can lighten them are few and far between due to very precise equipment being required.
Dual mass flywheels have intricate components. When you start shaving weight you start throwing off the balance aka harm the structural integrity of the flywheels. Prior to say 2001 Most flywheels were single mass, but those are few and far between on most manual cars today.
Old Dec 6, 2010 | 01:35 PM
I've found 10 pound steel evo flywheels. But not ralliart.
Old Dec 6, 2010 | 07:13 PM
Those are aluminum flywheels....performance oriented.
Old Dec 6, 2010 | 07:22 PM
If you're looking for a flywheel and a clutch for a cheap price just PM me.
Old Dec 7, 2010 | 07:14 AM
They also make lightweight steel flywheels for some cars. I've used aluminum flywheels before but it's not an option now with the rules I'll be running.
Old Dec 7, 2010 | 09:11 AM
You're out of luck. I've tried to source a custom lightwieght steel flywheel for my car and you can expect to pay about 900 bux.
Lightening the stock weight can't happne
...and you can't use a performance aluminum flywheel...only option you're left with is custom. I don't know maybe an old DSM flywheel would fit and you could machine that.
Old Dec 7, 2010 | 10:01 AM
I've thought about checking the old dsm flywheel. Probly have a couple six bolts laying around but not sure about a seven bolt. Guess I'll take it out and go from there.
