04-06 Ralliart Engine/Drivetrain (no forced induction)
alternator problems...
Old Dec 8, 2010 | 10:11 AM
tylerbeckum's Avatar
i have recently replaced the alternator for my car. for some reason it will not charge the battery. i have had the alternator and the battery checked and they are both good. the car then would work for a couple of days but then it will just stop working one day. what should i do? also if anyone could help me with pictures on where the alternator should be hooked up to be correct. i really need yalls help and fast...
Old Dec 8, 2010 | 10:37 AM
Beardly P's Avatar
Hail to the Beard
Did you replace it yourself? If not, I would take it back.
Old Dec 8, 2010 | 10:39 AM
i replaced it myself and i usually have no problems but i mean this is starting to become a hassle. i need something with pictures that will help me see where it needs to be hooked up at.
Old Dec 8, 2010 | 10:55 AM
Ralliartimus's Avatar
Double check all of your connections, both positive and negitave, make sure they are clean with no grease/dirt/paint/corrosion on the connecting surfaces.
Old Jan 13, 2011 | 07:35 AM
Mark22300's Avatar
u only got 3 thing to connect to ur alt a pos wire that goes to ur battorey a light grey clip and a black smaller clip i just did my alt to
