04-06 Ralliart Engine/Drivetrain (no forced induction)
? on stage 2 cam
Old Apr 7, 2011 | 05:46 PM
mazda8799's Avatar
? on stage 2 cam
do you really need a cam gear for just a stage 2? I know the valve springs would help but not absolutely necessary and was wondering if the cam gear is absolutely necessary.
thanks for the input.
Daniel
Old Apr 7, 2011 | 06:30 PM
Raikiri's Avatar
No
Old Apr 7, 2011 | 06:39 PM
GEJEN's Avatar
what he said^
Old Apr 7, 2011 | 11:24 PM
nerdbotSKRA's Avatar
RPW will say yes (because of their design):
From their site on stage 2 cams, " Valve springs are required and RPW has specifically matched valve springs in stock for the desired camshaft profile. There may be specific forced induction springs V naturally aspirated spring packages so please ask.
Vernier cam gear is recommended but not necessary "
but RRM will tell you no (because of their design):
I'd asked Rob recently on this topic after scoring a major deal on their no longer produced RRM stage 2, "This cam, or any from us, did not require any springs
or anything. It was designed to work with the stock valvetrain. That is
why we had it made that way. Other cams required a bunch of stuff and
we did not want that."
Old Apr 8, 2011 | 11:17 AM
mazda8799's Avatar
thanks for the help also does anyone know how much the rpw stage 2 cam will change the idle? will it be definite, sound aggressive?
Old Apr 8, 2011 | 04:54 PM
Raikiri's Avatar
nerdbot what you mean they stopped making the stage2 cam? Their street performer cam is their stage 2 from what rrm told me
Old Apr 8, 2011 | 08:43 PM
mazda8799's Avatar
yea they stopped making cams for the mivec. i talked to them just the other day. they said there were to many complications that they didn't want to keep up with.
Old Apr 8, 2011 | 08:44 PM
mazda8799's Avatar
i am really looking into the rpw stage 2 cam is really what i am talking bout.
Old Apr 8, 2011 | 09:38 PM
Raikiri's Avatar
what sort of complications were they talking about? now you're making me think my engine is going to blow up now
Old Apr 9, 2011 | 07:31 AM
lanzerralliart's Avatar
EvoM Super Moderator
I doubt it would blow up the car , it's probably more related to turbo guys getting the cam and having tuning problems or people that had the cam then went turbo an tuning. Either way I've heard of this complication but na is the way
Old Apr 9, 2011 | 09:25 AM
mazda8799's Avatar
they told me they really just didn't want to keep up with all the changes over the years and the different models and peoples different specifications and what not.
Old Apr 9, 2011 | 03:53 PM
mazda8799's Avatar
also looking into a rpw stage 3 cam and wondering what all i would need for it to work valve springs, tuning etc. and where to get them all? i am trying to find my budget as to much it is going to cost.
Old Apr 9, 2011 | 04:23 PM
kaoscage's Avatar
RPW does not have valve springs and you not need them... running an RPW stage 3 cam, still working on tune
Old Apr 10, 2011 | 02:45 AM
Maybe this will help
RPW Stage 2 Camshaft Profiles
1. The stage 2 profile is designed to be bolted on to either a modified or near stock vehicle.
2. The camshaft lift and duration are increased over standard for a slightly rough idle and acceleration.
3. The camshaft is designed to improve more mid range and top end power, with a slight loss of low rpm torque.
4. These camshafts can also be designed as a Supercharger / Turbo / Nitrous stage 2 camshaft profile where these items are added onto a Naturally Aspirated vehicle.
5. Valve springs are required and RPW has specifically matched valve springs in stock for the desired camshaft profile. There may be specific forced induction springs V naturally aspirated spring packages so please ask.
6. Vernier cam gear is recommended but not necessary
7. Vehicle will require in most circumstances, ECU modifications for fuelling.
8. There are no clearance issues with piston to valve clearance with these camshafts and for the majority of vehicles, we do not recommend going large than this camshaft profile
9. Vehicles running SOHC Mivec ie Ralliart Lancer only run a mild change to the primary lobes, and a mild change to secondary lobes.
Though it says above, the specs page says no need to worry about springs until stage 3.. hm..
Besides the changes or issues Rob's told me in my emails that the stage 2 grind was sublet work done by a third party cam guy, who went out of business.
Good luck in your search.
Old Apr 10, 2011 | 08:15 AM
Raikiri's Avatar
Sad to hear. Good thing I picked mine up before they were discontinued!
