04-06 Ralliart Engine/Drivetrain (no forced induction)
Noise from clutch problem
Old May 25, 2011 | 10:13 AM
railgunner50's Avatar
Ok so ive searched around and couldnt really find a solid awnser. So when i push my clutch down slowly theres a spot where it kinda squeeks like a tight spot or something. The sound reminds me of an old door creeking open. Its comming from the slave cylinder/ release fork area. Im about to hit 100k miles and havent had any problems with the clutch b4. Ive seen posts about the throwout berring but theres no chattering or effects to driving that ive noticed. Maybe time for a slave cylinder rebuild? Any response thanks!
Old May 25, 2011 | 10:21 AM
sharkm87's Avatar
my TOB would make noise before i changed ou tthe clutched... not sure if its the same for your car...but it would go away when clutch was pressed in..and always be there when clutch is not pressed
Old May 25, 2011 | 10:42 AM
Yeah that doesn't sound like my problem mine makes noise when the clutch travels like a cylinders binding or something. It does it the same weather the cars on or off.
Old May 25, 2011 | 10:54 AM
soulesswarrior's Avatar
Mine did that for awhile. Mainly on cold starts. But it went away. Only did it a couple months. This was back when the car had 50k. It's now at 130k.
Old May 25, 2011 | 01:22 PM
CrAnSwIcK's Avatar
is it coming from inside the clutch housing? could be like the ball behind the clutch fork inside the clutch housing, the slave cylinder actuator where it meets the fork, or the release bearing itself needs to be greased. Unless you can confirm it is coming from inside the cylinder.
Old May 25, 2011 | 07:47 PM
mikemike396's Avatar
My RA has a noise kinda like this. I can only hear it when the car is off. Like when i push the clutch in to put it into first gear. When the car is running, i cannot hear the squeak. Its done it since i have had the car.
Old May 25, 2011 | 08:06 PM
Thomar's Avatar
i think i know what you mean... i think its from one of the linkages the clutch cable is connected to.. when i push in the clutch i get a squeak... not worried by it.
Old May 25, 2011 | 08:31 PM
Ok guys ill look into it a little more and keep you guys updated so if the flywheel blows out the radiator we know there was a problem lol
Old May 25, 2011 | 09:51 PM
burner67's Avatar
I had this problem. i removed the clutch fork rubber boot and sprayed some lube like wd 40 on the connection points.. shuts it up once in a while it will come back but its not really noticeable.
Old May 26, 2011 | 09:24 AM
CrAnSwIcK's Avatar
WD-40 is garbage, use grease.
Old May 27, 2011 | 08:31 AM
RalliartN's Avatar
Clean and lube where the clutch cable ends terminate inside the engine bay.
Old Jul 1, 2011 | 07:17 PM
Jabl3s's Avatar
Has anyone else tried these techniques? There's so many random annoying noises that my car makes and I'm just trying to tackle them one at a time.
Old Jul 1, 2011 | 08:44 PM
GearDownSon's Avatar
Mine always squeaked while pressing.
Nothing to be scared of.
Old Jul 1, 2011 | 08:55 PM
Jabl3s's Avatar
Not scared. Just annoyed haha.
I would just like to know which solution is going to solve my issue before I tackle it (hopefully only once).
Old Jul 2, 2011 | 09:13 AM
CrAnSwIcK's Avatar
i would try everything we've suggested, grease cable ends, clutch fork, and see what happens then...
