Gas sensor is off?
Gas sensor is off?
I'm having a problem with my gas sensor I think? Everytime I'm parked on a hill or my car is parked to one side, my gas goes down to empty and it doesn't go up unless I leave my car on for about 10-15 minutes on idle on a flat surface. When I'm driving 65+ my gas seems to go down to empty but I know I still have about 3-5 gallons left in my gas tank. Also I could refill my car up with 10 bucks worth of gas and my gas will still read "E" what might be causing this problem? Is there a wire that's messed up or do I need a new fuel pump?
If you took out your back seat (very easy), you will see the top of them fuel tank. There are six 8mm bolts holding the fuel sending unit in place. Unscrew and pull out.
Reminder - no smoking.
This is for an evo but it's pretty much the same for the ralliart...
http://www.youtube.com/watch?v=BK73u1TK0VE
