04-06 Ralliart Engine/Drivetrain (no forced induction)
Fried ecu... help?
Old Aug 26, 2011 | 07:57 AM
-jhon-'s Avatar
Ok guys, been attempting to track this down and I think I know what could be wrong. Does the Ralliart have a "MFI/MPI Relay" Like the evo and other cars in the mitsu lineup? If so where is it located? I think that a diode or the relay itself could be malfunctioning and that is causing my power related problems. It seems that the P0606 is not just for Ecu malfunction, it also indicates a throttle control malfunction. I need to get this wagon up and running by tomorrow. Thanks for the support so far!
Old Aug 26, 2011 | 08:06 AM
-jhon-'s Avatar
Bah... If the MFI relay is located in the fuse box in the engine bay then that relay seams to be working fine. I even swaped the A/C relay with the MFI relay to see if the problem would go away but the car wont start. The ecu does not recive power and you cant hear the throttle actuating. What powers the MFI relay?
Old Aug 26, 2011 | 08:10 AM
-jhon-'s Avatar
Ok further reading in http://www.evoscan.com/technical-veh...hi-lancer-4g69 indicates that the MFI relay is turned on by the ecu. So what Relay powers the Ecu? Does it get power directly from ign by a fused line or is there an actual relay that powers the ecu function? If only I had a wiring diagram.
Old Aug 26, 2011 | 01:13 PM
-john-'s Avatar
Using the ECU pin out I manage to power up the Ecu threw one of the main power supply wires and she started up! Now I know that the ecu is ok and there must be a power supply issue somewhere in the system. Any one know where is the fuse for the ecu?
Old Aug 26, 2011 | 01:26 PM
dacib's Avatar
Told you so.... Sorry I can't help you more...
Old Aug 26, 2011 | 01:40 PM
-john-'s Avatar
I Just checked all the fuses, engine bay compartment and drivers foot well and all the fuses check out fine! I will just make a new circuit for the ecu and call it a day.
Old Sep 10, 2011 | 06:47 PM
chowetime's Avatar
reviving an oldish topic... but what was the solution - I was thinking along the lines of the key - I know ours have a immobiliser/keyreader in our cars and if the key battery goes flat or has a fault then this will not turn the car over to start/run... try your spare key
Old Sep 10, 2011 | 07:10 PM
mrojas91's Avatar
welll i dont think the key has a battery im thinking its more like digital or something like along those lines.. but yea it might have something to do with the immobalizer but more towards like the ecu programing to the whole car rather than they key. the key may have the original programing but the ecu dosent recongnize it. but thatss just me eliborating( brain storming) just to try an help
ezzey
Jul 19, 2016 04:48 PM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
SLO-EVO
Aug 19, 2011 02:19 AM
Grog
Apr 13, 2007 08:59 AM
