tranny prob
tranny prob
hey guys i just put in a new clutch but it is acting wierd... i am pretty sure i put it in right but idk anything is possible... the clutch is high as hell and it doesnt grab my gears at high rpms, any ideas?
can you feel the clutch engaging and disengaging? check for leaks, and bleed...
what did the flywheel look like when you did the clutch? is it possible that it's slipping?
You installed the clutch backwards. Happened once on a Mazda I previously owned and swapped a couple times. Gears were almost impossible to get in though.
If the pedal is really soft also, I'd say your slave is leaking. Pull the rubber over the slave and check for leaks.
It sucked and took a while to figure out. New clutches are labeled, I reinstalled an old one, didn't take too much time to think about it. The center (splined) part of the clutch is offset, it's longer on one side. I know now and will NEVER make that mistake again.
As for symptoms, it mainly slipped, gears almost impossible to get in, even when the engine off (not 100% sure of that last part).
bro im pretty sure i put it on right, it grabs all the gears fine at low rpms under 3k but if i go over that its like if the motor is too much and the clutch was made for a freakin suzuki swift lol. i dso remember idk if it effects it when we finished dropping the tranny my friend cleand the clutch with brake cleaner i was like wtf r u doing man and he said that is how u clean then that he does it all the time???
You can use brake cleaner on all friction materials, brakes, clutches, etc.
Have you peeled the rubber boots off your slave? No need to pull it hard or anything, even if there was no leaks at all, when I squeezed it, it blew oil all over the place, the thing was 100% full of brake fluid.
Also, what about your CMC?? Check in the Ralliart section, there is 2 threads about it covering pretty much everything.
I have an aftermarket clutch, and it killed my CMC and slave. Had to redo it all over.
