04-06 Ralliart Engine/Drivetrain (no forced induction)
Making my own Light Weight Crank Pulley
Old Jul 19, 2012 | 10:34 PM
soulesswarrior's Avatar
Originally Posted by RallyartRob
lanzeralliart is right titanium is a pain to machine i think u need diamond tips or really good ceramics at least for that but i could be wrong. But if u want it ill do it :P
No diamond needed. We use carbide at my shop. An titanium makes for a fun bonfire sometimes lol.
Old Jul 19, 2012 | 10:46 PM
SaulHudson's Avatar
Carbide cuts titanium.
Aluminium is strong enough if built right. Some aircraft are made of completely aluminium....
Old Jul 19, 2012 | 10:52 PM
RoMeIX's Avatar
I would think that just finding the best areas to remove material to save weight would be significantly more cost effective than starting from scratch with a lighter material.
Old Jul 20, 2012 | 12:25 PM
RallyartRob's Avatar
yes and no it depends on which way the forces act on the part
Old Jul 20, 2012 | 12:26 PM
yeah this will be my starting point but seeing as this project has to last like a year and will either pass me or not i think i need to go into a bit more detail :P
Old Jul 21, 2012 | 12:51 PM
RacerX-Ralliart's Avatar
It would be nice to if you make some power steering and alternator pulleys that are smaller so they spin faster
Old Jul 21, 2012 | 12:59 PM
2006_RA's Avatar
But then they'd be a higher load on the engine no ?
Old Jul 21, 2012 | 01:15 PM
I don't think so... same load but idk it would contradict the purpose of being underdriven right
Old Jul 21, 2012 | 02:29 PM
roblaza's Avatar
not really...it's the same concept as race cars wanting lighter wheels really... they're the could be the same identicaly size, BUT lbs lighter. the engine wont have to work as hard to turn them, making the engine spin up that much faster.
Old Jul 21, 2012 | 02:38 PM
^^ I was thinking something along the lines of that but wasn't sure..
Old Jul 22, 2012 | 09:29 AM
2006_RA's Avatar
We're addressing 2 different ideas.
Roblaza is keeping the crank pulley at stock diameter and making it lighter.
Racer X Ralliart is suggesting smaller (which I interpreted as diameter) accessory pulleys.
If you decrease the diameter of the accessory pulleys while keeping the crank pulley as OEM, how is it that you do not end up with a higher parasitic load on the engine ?
Old Jul 22, 2012 | 11:31 AM
I meant if he does a smaller diameter crank pulley to make the smaller diameter accessory pulleys.. The only way you would put a higher load is if you were to increase the power of the magnets in the alt.. Going to a smaller alt pulley will just increase the voltage output it will kill the brushes faster but if you go lighter say the stock is 1lb and you make it .5 that's less weight the crank has to turn the only reason I would suggest a smaller alt pulley is if the crank pulley is smaller in diameter otherwise just make it lighter
Old Jul 23, 2012 | 04:38 PM
the reason i want to keep the pulleys the oem size is because alot of engineering went into the proper diameters so that everything runs perfectly at idle and doesn't over charge or spin to fast and kill bearings and other components. If i was to downsize one thing then personally id want everything downsized other then the idler and tensioner to some sort of ratio so that everything spins the same but is smaller. I would think that decreasing the size of everything wouldn't be a bad idea but im not sure how to figure out the proper ratio or size for each component also the alt pulley is fairly small to begin with im not sure how much smaller i could make it.
Old Jul 23, 2012 | 04:43 PM
RoMeIX's Avatar
Gotcha!
Old Jul 23, 2012 | 05:00 PM
keithislegit's Avatar
Let me know if you still need the pulley. I'd be willing to sell you mine. I also would be interested in a full light weight pulley kit. That would be pretty awesome to see. Good luck with this!
