04-06 Ralliart Engine/Drivetrain (no forced induction)
Making my own Light Weight Crank Pulley
Old Jul 17, 2012 | 02:15 PM
RallyartRob's Avatar
So to graduate from my engineering course i need to complete a technical report. Im thinking about designing a light weight crank pulley for our 4g69 that is not an under drive since there are none available for our car.
-Would anyone be interested if i can actually design something that works and is reliable and has undergone testing?
-Also does anyone have a stock pulley that i could buy or have since i dont want to remove mine for the time being :P
Thanks Rob
Old Jul 17, 2012 | 02:28 PM
roblaza's Avatar
I'd be possibly interested In a lightened one... Provided it gets thoroughly tested and won't fubar any bushings ect...
Old Jul 18, 2012 | 03:57 AM
lanzerralliart's Avatar
EvoM Super Moderator
How about a multiple lightweight pulley kit?
CNC machining is quite expensive, its gone up more than double in the past 5 years. But check club4g.org fs section I saw an oem crank pulley there not to long ago.
Old Jul 18, 2012 | 04:22 AM
Ralliartize It's Avatar
PM me. I think I have one lying around.
Old Jul 18, 2012 | 04:53 AM
RalliartN's Avatar
Which is your design approach to lighten the stock pulley?
a) simply changing to something common and less dense, like say, aluminum
b) stay with steel but use FEA to help determine where to remove material so stresses in the wheel are uniform and below allowable strength/fatigue levels
c) lighter material and intelligent material removal
d) costs be damned, the most suitable exotic material will be used
Old Jul 18, 2012 | 06:12 AM
kapitolralliart's Avatar
..ditto
Old Jul 18, 2012 | 06:54 AM
CrAnSwIcK's Avatar
can you make mine out of titanium?
Old Jul 18, 2012 | 10:38 AM
Titanium was 12 bucks a pound in 2005 now it's 70 bucks a pound, machining it would shoot the price up for sure since harder cutting materials would be needed.
Old Jul 18, 2012 | 10:52 AM
i use to work at a small cnc shop so i can probably ask them for some help with that, as for the club4g all i have ever seen are underdrive which i dont want. But for roblaza yeah i would test it mad because it would be part of my project, also if i wont trust it on my car i wouldnt sell it to anyone else
Old Jul 18, 2012 | 11:34 AM
A quick search and.....
http://club4g.org/board/automotive-s...ey-intake.html
http://club4g.org/board/automotive-s...ring-30-a.html
Old Jul 18, 2012 | 03:30 PM
bakuro117's Avatar
..ditto
Double ditto. Id be down for one.
I was thinking along these lines too. What is your plan for the project so far?
Old Jul 19, 2012 | 03:33 PM
lanzeralliart is right titanium is a pain to machine i think u need diamond tips or really good ceramics at least for that but i could be wrong. But if u want it ill do it :P
Old Jul 19, 2012 | 03:35 PM
awesome thanks for that i will look into that when i get the go ahead with my report
Old Jul 19, 2012 | 03:41 PM
sorry i didnt reply sooner i missed this.
a) aluminum i think would be to soft so i would avoid that but also look at the engineering side and see if it can hold up to the forces if it can then aluminum could be an option,
b) this was my initial idea use an oem to get all my sizes and then using cad and good old math determine where and how much i can remove to light weight it. and then do some stress test see if it can hold up to the forces and if it does i will do two dyno runs on my car (before after) see if it helps at all. wishfull thinking says +10ish hp if im lucky :P and bit better throttle response.
C) yes if lighter material is strong enough and lighter then the original
d) will see lol i might make a gold plated one for fun if i was that rich :P
thanks rob
Old Jul 19, 2012 | 07:43 PM
CrAnSwIcK's Avatar
i was joking, i know how expensive that stuff is, i don't want a $400 crank pulley
