04-06 Ralliart Engine/Drivetrain (no forced induction)
Wideband Install?
Old Sep 14, 2012 | 05:43 AM
Darewood's Avatar
Wideband Install?
Question for Wideband installation for any who have done it! Since I couldn't find any concrete information for our year, would following this https://www.evolutionm.net/forums/09...-wideband.html Be similar for installation?
Also I remember that there is an O2 sensor bung on the OBX headers on one of the pipes, would I be able to use this ? Or should I just get one welded on the underneath near the first O2 Sesnor?
Old Sep 14, 2012 | 06:17 AM
nerdbotSKRA's Avatar
That 09 ralliart how-to can give you a general idea, but won't entirely be the same thing.
I referenced the same thing when I did mine lol.
Similarly I pulled the wideband o2 sensor wiring/harness through the existing o2 sensor grommet on the passenger side, which required removing the kick panel and pulling the carpet up (though I modified the area around it slightly with a dremel to etch in a little notch to let the wire to sit without getting pinched, this is not necessary).
I would recommend capping the bung on the OBX header's runners if you were intending to install a wideband there, I wouldn't recommend it for an o2 or wideband sensor because the exhaust gas is too hot at that location, I don't imagine it would last very long.
My wideband bung is welded in about 2-3 inches forward from the pre-cat o2 (bank 1), installed at about an 11 o'clock, I would recommend a 2 o'clock position just so your wiring is more-so on the correct side, I tucked my little bit of excess wire using some sort of existing wiring strap, almost like a twist tie on the bottom of the car near the cat.
I have a glowshift wideband, the hardest part was hiding the excess wire that came with the bosch sensor haha
Old Sep 14, 2012 | 06:33 AM
Darewood's Avatar
Thanks for the input! The bung on the headers have been capped, I just remember I had one there. Makes sense that it wouldn't last long due to the heat. All in all it really doesn't seem like that difficult of a job.
Old Sep 14, 2012 | 07:06 AM
CrAnSwIcK's Avatar
18-20 inches downstream of the head should be fine...
03chi-town0Z
12
Nov 30, 2014 09:21 PM
03chi-town0Z
May 12, 2011 10:20 AM
03chi-town0Z
May 12, 2011 10:05 AM
laflsyl10
Evo X How Tos / Installations
Jan 2, 2010 04:56 PM
