Spark Plug/Valve Cover Gasket
Finally got a nice spring day in Northern Indiana and decided to do my first tune up on my '06 Ralliart I bought in January. When pulling my plugs, I noticed there was a small amount of oil in the bore where my plugs go. It's wasn't pooled in the bottom of the bore, or caked on the plugs. Just small amounts on the bore walls and actual plug wire/pack. Do I need to hold off on throwing my new Densos in, or is that small amount normal?
This is my first post as a virgin Ralliart owner, so you guys might have to bare with me for a bit. Haha
you would see a leak, a bad leak would have wet oil, a slow leak would show a collection of oily mud at the seam where the head meets the block...but if you're pulling the valve cover you may as well replace its gasket since it probably hasn't been done or at least not in a while...
Reading first, ask later. Chances are unless there's some odd problem that isnt specific to just your car, then it's most likely already been asked somewhere here on the forum
glad to know you know how to use the search function
There's finally a RA owner in IN! lol i drove through there like 2 weeks ago and never saw one 04-06 lancer.
It was out of commission for short periods of time. After about a month of owning it I was turning, going about 10MPH, and my lower control arm sheared off and did a little damage to my CV shaft in the process. I replaced the lower control and CV shaft on both sides. Then a week after fixing that and getting my alignment done, I was driving a little liberally and my car went into limp mode, so it sat for about another week while I was assessing that situation. Needless to say, I haven't been able to put many miles on it. Haha
And I can get the felpro kit for $20, which I plan on doing this weekend, as opposed to $25 for just the plug tube seals.
Also found some throttle bodies on eBay off the Endeavors for around $85, so I might be heading in that direction as well if I can get them shipped in time
Yeah.. That's what it would have looked like if it would've stayed intact. I had a control arm hanging while the ball joint was right where it was supposed to be.
Then I got a call from the tire place that was doing my alignment to say they needed to shave my strut bolt on the side the control arm broke because they couldn't adjust it enough. I'd say it was slightly bent from the sudden skid stop I was introduced to when my control arm broke. Guess what else I'll be replacing here shortly
haha
haha
