04-06 Ralliart Engine/Drivetrain (no forced induction)
crank shaft sensor replacement
Old Aug 4, 2013 | 10:28 AM
ralliart 04 21's Avatar
so last week my service engine soon light came on , so I took it to pepboys to run the code and it came up replace crankshaft angle senor . so this will be the second time im replacing it , the last time I went to the dealership , and it cost 415 . i can get the oem part for 90 is the a easier way to do this , then have to take off all the pullys and belts .
Old Aug 4, 2013 | 10:45 AM
CrAnSwIcK's Avatar
nope...belt, pulleys and lower timing cover...
what's your mileage? and how many miles since the last time you changed it...my car has 220,000km and has never had a crank angle sensor fail...
the thing is, if the crank angle sensor failed the car shouldn't run, maybe i'm wrong, but I know for sure the car won't start with out a cam angle signal. I would check the connector and wiring if sensor keep going out...
I would check your battery terminals are tight, clear the code and see if it comes up again...
Old Aug 4, 2013 | 12:06 PM
RacerX-Ralliart's Avatar
Yeah I don't think it would run if it was bad because it's a position sensor like the cam sensor and the ecu uses it for timing and if it wasn't getting a signal than timing wouldnt be accurate And would damage internals... How long ago did the dealer do the job? Did the offer any type of warranty?
Old Aug 4, 2013 | 02:06 PM
the first time I had 65,000 miles on the car, now I have 140,000 miles . what's happening is that the car wont start for a few minutes , and then it starts. this was the code I got p0335
Old Aug 4, 2013 | 02:22 PM
O wow I'm sorry to hear that... The sensor is about 50 bucks if you plan to do it yourself.. I would check all the wires that go to the sensor.. If I remember correctly the timing cover acts like part of the wiring...
Old Aug 4, 2013 | 03:12 PM
CrAnSwIcK's Avatar
yeah I would say it's more likely a connection issue if it's intermittent...
MisUnderStood
Dec 2, 2016 06:49 AM
mitsu13
Nov 12, 2016 10:00 AM
SharkyPR
Apr 14, 2016 06:00 PM
ryan_db
74
Jan 2, 2015 06:27 PM
