04-06 Ralliart Engine/Drivetrain (no forced induction)
? about rrm intake i baught
Old Mar 6, 2004 | 04:39 PM
mitsumichael7's Avatar
If I remember correctly, you have to remove a bolt from the tranny and then re-bolt it after you place the mounting bracket in place. if I was there I could show you, but I am not driving 10hrs to show you a bolt...lol.
Old Mar 6, 2004 | 04:40 PM
jaymz916's Avatar
yeah then he should run the piping down and line it up to see which bolt comes out.
Old Mar 6, 2004 | 04:46 PM
ski10804life's Avatar
yeah it is wierd my friend just gave me an idea, he has a rsx type-s and he had to kut a plastic peice to fit his injen cold air intake on there, but i am still not seeing a place where i can bolt this on
Old Mar 6, 2004 | 04:48 PM
yeah mitsumichael7 do you know where abouts on the tranny the bolt is so i might have an idea i am so lost when looking at this haha i cant see a bolt that would line up with anything
Old Mar 6, 2004 | 04:50 PM
jaymz916's Avatar
yeah i;m sorry can't be more of a help, never seen the mivec engine up close, and mine bolted to the frame, yours apparently bolts to the tranny.
Old Mar 6, 2004 | 04:51 PM
no no jaymz916 thanks alot for your help i just wish rrm would have sent some sort of directions haha thanks
Old Mar 6, 2004 | 04:54 PM
jaymz916's Avatar
no prob, hope you figure it out, and see what that thing will do, i;m jealous of your 160 ponies.
Old Mar 6, 2004 | 04:58 PM
hahaha yeah thanks man
Old Mar 6, 2004 | 04:59 PM
does anyone have a diagram or a picture of how this RA intake is suposedto be put on
Old Mar 6, 2004 | 05:20 PM
ski,
hold on I am going to go out to my car and take a look so I can give you an accurate description
Old Mar 6, 2004 | 05:26 PM
Sweet, thanx man
Old Mar 6, 2004 | 05:27 PM
ok man, look at the tranny right behind the black rubber radiator hose and you will see a little metal plate that has metal lines coming out of it. It is fairly obvious when you look. It is directly under the left side of the black container holding the battery. there are 2 bolts connecting that bracket to the tranny. Bolt the intake braket to the bolt on the right. You will have to remove the bolt on the tranny. Line up the hole and then replace the original bolt into the tranny. that is as basic as I can make it man.
Old Mar 6, 2004 | 05:35 PM
ok thanks alot man lemme go check it out
Old Mar 6, 2004 | 05:47 PM
let me know if you got it.
Old Mar 6, 2004 | 08:46 PM
LDB's Avatar
LDB
So did it fit? Enquiring minds want to know.
