5 Speed to 6 Speed Change
of course it will bolt up, it's a 4G6x engine block...the question is more about whether a FWD lancer differential will fit in the case and if the side where the output shaft for the transfer case would accommodate an axle seal...the diff bearings are different between the gear boxes, so I have a feeling this will not work "out-of the box", but I suppose anything is possible...
xtnct
12
May 2, 2009 12:10 PM
RUN FOREST RUN
Aug 26, 2008 10:22 AM
Blue Evo 8
22
Apr 27, 2006 08:48 PM
